Engine stutter problem
If anyone has any suggestions, I would appreciate it. I just recently hit my 1000 mile mark, so I have been able to push my car. Then I found a problem of some sort.
When I accelerate pretty hard shifting from 1rst to 2ndI have no problems all the way up to 7K RPM, even 7500RPM. But when I reach about 6000-6500rpm in 2nd or 3rd fast the motor hit a cut off of some sort. The whole car starts stuttering. To me it seems like either the car isn't receiving fuel or hitting a spark anymore. If I back of the gas a little and ease back on it, it is fine. Any help? -Dave |
It may be a fuel cut for boost spiking issue if the X's come with it. Ask the dealer, thats the joy of WARRENTY!!!!!!!
dont worry everybody is getting that. some say cone filter eliminates it but not for me. maybe that and a boost controller will help
Is it all the time or when you are lower on fuel?
I never noticed if I was low on fuel, but I would guess not, sinse I always try to stay above half tank
My car did that too...
When I floored it on 3rd gear, around 5000 to 6000 rpm, the car stuttered. I drove my car about 1,000 miles, and the problem seems to have dissipated. Now, it's running pretty good. I think it's because the car is running too rich (I'm no expert in cars, just guessing). If you look at those dyno graphs of stock EVO X, you can see that torque curb drops dramatically around 5000 rpm.
I have a mbc and filter when I started putting the pedal down and still had the same issue. Another member said after he ran the car for a while at the track the computer learned to tune itself and it ran great. So i have been running the car harder when I can and it does seem to be getting alot better know.
That might be true. I think my stuttering problem dissappeared after few hard driving.
Originally Posted by Jooyoung99
(Post 5368867)
My stuttered the within the first 485-692 miles, on and off, and now it just went away. |
Keep in mind the X has a break in program that runs to something like 1200-1500 miles
Originally Posted by evo_Eks
(Post 5368318)
Originally Posted by CharlesJ
(Post 5369152)
Originally Posted by EvoXstylin
(Post 5369767)
thats what the dealer says in the manual it says 500 miles
Originally Posted by Kdogg71
(Post 5369813)
I don't think he's talking about the break in period...if I'm not mistaken, he's talking about some ECU trickery that occurs until 1200-1500 miles.
(Post 5369825)
ohh ok, gotcha
what youre describing is the sputtering that occurs on some of the X's out there at WOT.
Its a problem that Mitsu is aware of. There should be a flash sometime at the end of this month or mid-april. Check with your local dealer about the flash... Mine is doing the same thing. |
