Evo feels sluggish and heavy...
After 2.5 years of owning I can safely say the X feels little sluggish and heavy. Not sure what it is but it doesn't have the get and go like it should but once it gets there its a blast to drive. I'm thinking maybe I need a re-tune? The only thing I've done to it is tune, aem intake, test pipe and dyno at 310hp. I've recently added some wheels that are a bit heavier then stock and a recaro child seat that weighs +50lb! Not sure if it's the added weight or not but it is sluuuuggish!! Any inputs?
you've gotten used to the power, that's why modding exists :)
Sell it and get a fiat 500 super light
put her back on the dyno and see if you've really lost power or if it's in your head
Big wheels will make a car's acceleration and handling feel sluggish.
+1 change your wheels.... lighter wheels will also helps on your mpg
Change your wheels or drive something with less than 150hp for a couple of weeks, then get back in your evo.
you got used to it...do a tune up, change the oil, air filter and spark plugs (at the same time),get lighter wheels and it should feel peppy in the lower rpms
I think you got used to the power and the wheels aren't helping. I say get a couple more mods and a retune and invest in some nicer/lighter wheels.
Put the Evo on a diet, tighten up the suspension and get a tune.....just throwing some ideas out there...
Originally Posted by Kracka
(Post 9768869)
Try cleaning the throttle body and run some fuel injection cleaner in it.
Can it be a sign of my stock clutch I going out? I'm at 35k miles.
I think if the clutch was going out the car would still rev fine, the rev's would just slip because the clutch wouldn't be holding anymore. I don't think it would slow down how fast your car revs tho..
Originally Posted by Jookies
(Post 9769264)
