Sponsored by:
Sponsored by: CARiD
Evo feels sluggish and heavy...
Old Nov 23, 2011 | 07:59 AM
SpeedI2acerX's Avatar
After 2.5 years of owning I can safely say the X feels little sluggish and heavy. Not sure what it is but it doesn't have the get and go like it should but once it gets there its a blast to drive. I'm thinking maybe I need a re-tune? The only thing I've done to it is tune, aem intake, test pipe and dyno at 310hp. I've recently added some wheels that are a bit heavier then stock and a recaro child seat that weighs +50lb! Not sure if it's the added weight or not but it is sluuuuggish!! Any inputs?
Old Nov 23, 2011 | 08:02 AM
Evoardo IX's Avatar
you've gotten used to the power, that's why modding exists
Old Nov 23, 2011 | 08:09 AM
EvilRob's Avatar
Sell it and get a fiat 500 super light
Old Nov 23, 2011 | 08:20 AM
jdmEviL8's Avatar
put her back on the dyno and see if you've really lost power or if it's in your head
Old Nov 23, 2011 | 08:26 AM
Kracka's Avatar
Big wheels will make a car's acceleration and handling feel sluggish.
Old Nov 23, 2011 | 09:01 AM
chazyronnie's Avatar
+1 change your wheels.... lighter wheels will also helps on your mpg
Old Nov 23, 2011 | 09:04 AM
ThunderOZ's Avatar
Change your wheels or drive something with less than 150hp for a couple of weeks, then get back in your evo.
Old Nov 23, 2011 | 09:07 AM
dmcghie's Avatar
you got used to it...do a tune up, change the oil, air filter and spark plugs (at the same time),get lighter wheels and it should feel peppy in the lower rpms
Old Nov 23, 2011 | 09:15 AM
ugakirk's Avatar
I think you got used to the power and the wheels aren't helping. I say get a couple more mods and a retune and invest in some nicer/lighter wheels.
Old Nov 23, 2011 | 09:31 AM
MAS2377TECH's Avatar
From: Philly, Germany, Japan, UK...South Dakota (Da Sticks).......
Put the Evo on a diet, tighten up the suspension and get a tune.....just throwing some ideas out there...
Old Nov 23, 2011 | 09:47 AM
CurseDSM's Avatar
Changes the final drive as well
Old Nov 23, 2011 | 09:51 AM
Get Rad's Avatar
Try cleaning the throttle body and run some fuel injection cleaner in it.
Old Nov 23, 2011 | 10:56 AM
Can it be a sign of my stock clutch I going out? I'm at 35k miles.
Old Nov 23, 2011 | 11:09 AM
Jookies's Avatar
I think if the clutch was going out the car would still rev fine, the rev's would just slip because the clutch wouldn't be holding anymore. I don't think it would slow down how fast your car revs tho..
Old Nov 23, 2011 | 11:21 AM
Get Rad's Avatar
Exactly, the clutch going would have nothing to do with your car being sluggish. It would just slip.
