Good Place For A Boost Gauge???
I project an angled and upward molded design being mounted in the cubby hole under the climate control unit. But that means looking down to see your gauges
A pillar gauges on teh X = not so much
that timer in the picture above only actually appeared in the concept along with suede inserts in the seat and dash and headliner. The actual production car will not have that timer and also be lacking any suede in the concept. It kinda sux but what can you do that would be a perfect place for a boost gauge. Make it outta fiberglass and mount it just like that. That how i am going to do mine.
Make a panel for the lower cubby, mount the hvac control box behind it, relocate the knobs to the panel, use the stock hvac knob position holes for gauges. Someone on here did it, looks perfect. I think it was VividRacing, one of the shops that first got it.
Have any of you guys actually looked at the side airbags???
Pop the pillar off and take a look. The actual airbag isn't on the plastic pillar (it's on the metal a-pillar part) and starts at the top of the pillar and travels down only about 6-7".
IMO, the best bet would be a vent gauge like pictured above. Another thing a vendor ought to get on is a single din radio replacement that goes toward the bottom and a slot for two or three gauge holes in the center between the vents. That would be trick.
the air bag will push the plastic cover off but unless your mounting the gauges high they should keep the cover from going to far. When i get a chance I will post some pic of mounting them low and far away from the airbag. if you are really worried about the gauges then place a set screw at the bottom of the A pillar to keep the cover from becoming completly detached. thus holding your gauges in place on the plastic.
