How to insall a bov on the evolution x
research before you ask a question like that... not trying to be an ***. anyone that owns a turbo car should know the answer to that...
Many of the BOVs you can purchase for the X will be a "bolt-in" replacement in that you just remove the clamps on the BOV inlet and outlet, slide off the inlet and discharge tubing and replace the factory unit with the aftermarket BOV. If you purchase a valve that has a non-tube style inlet flange, most manufacturers will have a tube-style inlet adapter that will make it a bolt-in install. We carry several, so if you need any help just let us know. Thanks and good luck!
Tom
Tom
