Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
New Gauges Setup! Looks OEM + AC Control Relocation
Old May 14, 2009 | 11:43 AM
ZWingerRyRy's Avatar
Alright after tearing my car apart quite a few times i was getting
annoyed with the boost gauge in a cup dealy on the steering wheel
just wasnt cutting it for me, since i was also using adhesive and not
drilling into the wheel hub, i needed something even more clean
and better position. Some might know me from this post
https://www.evolutionm.net/forums/ev...lean-hell.html
Well heres some pics so far, im just waiting on my next 2 gauges to
come to finish off the look, then possibly figure a way to fabricate a
wall into the glove box to finish off the ac controls.
Then relocated the ac controls to glove box til i can make a panel in the glove box for it. Unfortunatly you cant just unplug it and store it somewhere til then as the ac will automatically control the air if the controls arent plugged in and keep the air on 24/7 =\ Unless you intend on riding the ac.
These are 52mm im not sure but it might be possible to fit bigger. These 52mm Defi's came with a adhesive with a foam outer to keep the gauge snug in the cup but not stuck. So extra gauge size might work. Lemme know if anyone is interested ill have a write up very quickly if needed. Thanks
Old May 14, 2009 | 11:47 AM
antics22's Avatar
you can always relocate the ac knobs below that. A couple of people including myself have already done this... I can't say for others but personally, I didnt post it because its pretty labor intensive! You look like you've got the skills though, so try it! it fits below with a little plastic trimming!
Old May 14, 2009 | 11:53 AM
Hmm ill have to try that out. Just fabricate a panel below to hold it?
Old May 14, 2009 | 03:38 PM
Juju702's Avatar
Very clean, me likey!!
Old May 14, 2009 | 03:39 PM
griffeyr's Avatar
Your boost gauge looks lonely
Old May 14, 2009 | 03:44 PM
mmartahus's Avatar
sweet, yea get another 2 gauges
Old May 14, 2009 | 03:55 PM
mitsumanny's Avatar
looks great, if there is a chance to bring the gauges out a bit it might make them easier to c while driving though. Real clean though i like
Old May 14, 2009 | 04:34 PM
nicolas916's Avatar
looks good, now slap in the other 2 gauges and it will look even cleaner.
Old May 14, 2009 | 05:37 PM
Excalibur's Avatar
I wish you could do this and keep the controls where they're supposed to be somehow.
Old May 14, 2009 | 05:52 PM
Ya unfortunatly i couldnt find anyother place =\ I tried to figure every possible place but the wire for the ac was quiet short and multiwired with the passenge airbag/hazard/pass seat unit. I put my boost back up by the steering wheel until i figure out a solution. Maybe egt/temp/oil pressure there and boost on steering wheel would be good. Someone needs to make a cubby hole panel mod to fit gauges asap.
Old May 14, 2009 | 06:51 PM
Clark_Kent's Avatar
Very clean and creative however I don't see the point of installing gauges outside of your line of sight...especially, gauges that don't playback. How excellent would it be to have your speedometer or tachometer outside of your line of sight? It would make for a pain in the *** and it would almost render the gauge useless and impractical.
Old May 14, 2009 | 07:06 PM
ScottSpeed21's Avatar
Nice looking and very clean, but I agree with Clark Kent ^
Old May 14, 2009 | 08:28 PM
boostzealot's Avatar
damn thats bad as hell! very nice job and even though its not all done, it still looks quite promising. keep up the stellar work
Old May 14, 2009 | 09:30 PM
Not all gauges need to be in line of sight. Im pretty sure you dont need a constant view of your egt,pressure,temp,volt, etc.. on a 24/7 basis. Boost was just there for trial purposes. My boost stays at my steering hub. Not sure how a speedo or tach relate to this setup in the first place And i can see the gauges perfectly, i have no issues viewing them.
Old May 14, 2009 | 10:08 PM
EVOX56's Avatar
wow, that is a pretty sweet setup. can't wait to see the finish product!
