Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
DIY Injectors EVOX
Old Feb 26, 2010 | 02:16 PM
mlomker's Avatar
There are two black spacers between the Fuel Rail that hold keep the Inj spaced.. after dc the one of the 2 bolts becareful not to drop them under bec. it will be a pita if you do
I did drop one of mine last night. lol. The parts retriever came to my rescue.
Old Feb 26, 2010 | 02:49 PM
chidevildog's Avatar
need one of those!.. I must have at least 2 14mm's in there and a couple of washers/nuts... damn it...
Old Mar 11, 2010 | 04:04 AM
dek0026's Avatar
So I did this yesterday and I forgot about the black spacers and dropped them both. I friggin hate myself now. I am pretty sure they fell straight to the underpanel and I really don't want to take it off to get them. I'd rather they just fall out with some driving. Can I buy these somewhere? I am sure pretty much every mitsu uses them.
Old Mar 11, 2010 | 06:05 AM
dek0026's Avatar
part number for those like me: MD095402 and they're 4 bucks a pop.
Old Mar 11, 2010 | 10:51 AM
I dropped one of those and almost gave up on it.. but LUCKILY I saw it sticking out looking right at me right underneath the fuel rail.. I was lucky! but yea it would be a PITA to loose those.. but when you get your next set.. make sure your injectors are seated properly before you torque/screw them in... apply liberal amount of lube/oil on them so the "O" rings are inserted in properly!
Old Mar 11, 2010 | 03:08 PM
ikt's Avatar
ikt
If you unplug your fuel pump, then crank the engine a few times, it will burn out the fuel in the system and not spray gas all over the place
Old Mar 11, 2010 | 03:22 PM
evolvedx's Avatar
I dropped a spacer when I did mine. Needed a fish stick (used to pull electrical wires) and a wad of gum to get it back, macgyver style.
To the OP: that Walbro fuel sock is no good in E85. It WILL come apart with time. Get a 8/9 fuel sock from Blaqops ASAP.
Old Mar 11, 2010 | 03:27 PM
But I got the kit from Blaqops...?
Old Mar 11, 2010 | 03:41 PM
evolvedx's Avatar
I'm just going off the pic you posted. The sock shown there is a Walbro sock, not an 8/9 sock. Did the sock come with the Blaqops kit?
Old Mar 11, 2010 | 04:53 PM
dek0026's Avatar
Thanks for the how-to. I helped me out today and yesteray.
So I dropped the two spacers like i mentioned. Well i went back to it today and there was one looking righ at me just like. then i struck the underpanel a few times and the other one fel to the floor. i was lucky.
got it all installed and it seems to work without leaking. one thing to note was that is was hard as hell to push the bottom o-rings into the intake manifold.
Old Mar 11, 2010 | 09:12 PM
wow how bout that! Im glad you got those bad boys back!
Old Mar 22, 2010 | 07:25 PM
darqnez's Avatar
That is the BlaqOps filter in the picture, not cotton, just over exposed so you cant really see the blue internals inside through the mesh.
Old Mar 24, 2010 | 12:48 PM
evolvedx's Avatar
Very well then, excuse my concern.
Old Mar 24, 2010 | 01:16 PM
BlueX702's Avatar
Nice write up! I will use this when I get my injectors. Are you good running around like this or do you need to get a tune right away?
Old Mar 24, 2010 | 01:26 PM
Blue I would say get it tuned right after looking at your sig. you are full bolt-ons... yea I would def.. go with a tune.
