Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
how to request , air fuel ratio
Old Mar 19, 2010 | 08:36 PM
villero1834's Avatar
Talking how to request , air fuel ratio
i bought an air fuel ratio glowshift from another member here in evo m , so , no instructions or nothing , i have three wires black and red (neg and pos) and a gray wire that says that goes to the sender in the o2 sensor now im always trying to do it my self, but this time i dont know how to , i know theres more than one here that has an air fuel ratio gauge , so help me please , again only one wire to the o2 sensor , which wire do i have to tap into and which 02 sensor the first on i guess , thanks
Old Mar 23, 2010 | 07:46 PM
come on 75 views no answers , i need help please
Old Mar 23, 2010 | 08:52 PM
05VIII's Avatar
prolly because they see its a narrow band gauge which is pointless. it gives you a light show and nothing else. but to install it you need to tap that gray wire into the front o2 sensor wire from your ecu. look up ecu wiring diagram for your car and find the front o2 sensor and tap into it.
Old Mar 23, 2010 | 09:18 PM
thanks
Old May 5, 2011 | 08:53 AM
Colbyy's Avatar
Why is it pointless? I have the same gauge along with oil press and boost i have them all in just not hooked up all the way, but if you say its pointless should i even bother hooking it up to the o2 sensor??
Old May 5, 2011 | 06:40 PM
itznoraa's Avatar
Should spend your money on a wideband, and ditch the narrowband because the wideband is more accurate.
Old May 15, 2011 | 10:49 AM
ErnGotti's Avatar
Go here:
http://roadraceengineering.com/evox/...-ecuwiring.htm
Use Pin#38. Heated O2 Sensor Front. The ECU is in the engine bay. Very easy to snap back the black plastic clip to remove the plug. Its the upper plug you're gonna pull off so no need to fret with the lower one. Print the diagram out and bring it outside to the car to follow and use a wire tap (I used the piggyback style since there seems to be too little room for a T-tap). I installed this gauge, although find it rather pointless as well because narrow bands are more accurate on N/A engines, not our cars, but at least you'll know you're not running lean. It will almost always be rich, FYI...
Randal
Nov 4, 2012 04:19 PM
Mervin
May 7, 2011 04:56 AM
extremepsi
27
Nov 15, 2006 07:11 AM
5!grand!slam
Sep 13, 2006 02:30 AM
maxum17ft
Lancer Engine Management / Tuning Forums
23
Aug 13, 2006 12:23 AM
