Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Cusco EVO X Catch Can
Old Jun 13, 2011 | 07:15 AM
Fede's Avatar
Just thinking but... if I use only one catch can, with a T tube, head head - can, it will work? Assuming that can be a different pressure in the 2 parts of the engine connected togheter, that will be always higher that the one in the tank due to intake pressure so I think there will be only one flow direction. Correct me if I'm wrong.
Old Jun 13, 2011 | 08:22 AM
xbaybiixsophx's Avatar
How long roughly does it take to install the catch can? looking good btw
Old Jun 13, 2011 | 09:26 AM
ZX-10RR's Avatar
I'd say about a hour it would have been quicker but my hose cutters
Weren't very sharp so it took longer to cut straight.
Old Jun 13, 2011 | 11:11 AM
Does it run the same after install or does it require a remap of any kind? I was planning on putting one on mine but was unsure if it would effect its running etc as the UK models seem to have different maps?
Old Jun 13, 2011 | 03:25 PM
ZX-10RR's Avatar
To my understanding it doesnt require any changes in the map. Ive ask this question to tuners and they all say no.
Cheers,
Old Jun 14, 2011 | 12:40 AM
Fede's Avatar
Bad idea?
Old Jun 14, 2011 | 05:56 AM
Slyy's Avatar
Originally Posted by goevox
i say again, all you guys are bypassing the breather hose, pcv is on the other side. please double check your work.
I believe he is right.
Should be the pcv valve from the crankcase.
Old Jun 14, 2011 | 08:08 AM
ZX-10RR's Avatar
There are quite a few people running one or two catch cans. I would think that one is better than none? So I went this route you can always add another.
Old Jun 14, 2011 | 05:34 PM
sstevojr's Avatar
It was done intentionally. That breather line dumps the nastiest oil sludge right into the turbo (literally 3 inches from the compressor) via the intake. The goal is maintaining the longevity of the turbo and intercooler by keeping oil out.
Old Jun 19, 2011 | 11:07 PM
goevox's Avatar
you should take your inlet tube off and look right at the turbo compressor wheel, i bet there is going to be no oil present. now take off your map sensor on your intake manifold and peek inside the manifold, there is going to be a **** load of oil present there.
air goes in from the breather hose and out the pcv, you guys should be routing the pcv hose instead of the breather.
Old Jun 20, 2011 | 04:16 PM
sstevojr's Avatar
Actually, I only decided to solve this issue AFTER replacing my IC & IC piping and finding a layer of oil on everything (including the turbo inlet/outlet). Then after 1 track day I looked at the catch can, low and behold a 1/2" of the nastiest sludge ever; now noticably absent from my turbo, piping AND intercooler (most important part). But thanks for telling me it's pointless
Let me guess, you only drive your car in straight lines on perfectly flat roads.
I'm not disputing the pcv is also a good idea, simply your assumption that mine is worthless
Old Jun 22, 2011 | 06:39 PM
Gooseman396's Avatar
I picked up the Saikou Michi Dual Stage 1 kit and did both. I've emptied it once after about 3,000 miles of spirited driving no track time and go about 1/2" in the bottom of a glass that was just gas and oil.....this came only from the pcv side passenger side opened the breather side (intake side) and there was nothing. I would suggest if you are going to do a catch can do them both and at the least do the passenger pcv side. Just my 2 cents.
Old Jul 14, 2011 | 07:36 PM
KahoX's Avatar
have you guys done this on the 2010 model? the valve cover is not metal and the breather port is bigger than the one in the picture (2008). The cusco hose is too small for it so i reroute it to the other side...
here are some picture.. let me know if this set-up is okay to run.
^ This is how i have it for now.. i'll prby get the hose to re-circulate it back to burn it. Would you guys have done what i did here? if not, why?
Old Jul 14, 2011 | 09:22 PM
goevox's Avatar
you should have the hose coming out of the cusco can go back into your manifold, instead of blocking that factory hose
Old Jul 15, 2011 | 01:02 AM
dericchan1's Avatar
Can someone please PM me where can I order the Cusco oil catch can for the X?
Thanks
