Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Help! What is this??
Old May 23, 2012 | 09:16 PM
DreamerAndy's Avatar
Registered User
I was trying to remove turbo but there were many thing that were in the way. So, I decided to put them aside and [picture 1] was one of them. I unbolted it and realized that something was coming out from there. It was a scarlet liquid! [Picture 2] I don't know what it is and am freaked out. Do you have any idea what it is and how to refill it? Please I need your help!
Old May 24, 2012 | 05:33 AM
OZ_2435's Avatar
I see you have a MR. Is that the line to the transmission cooler?
Old May 24, 2012 | 05:51 AM
Phantom09's Avatar
that's something you shouldn't had touched! im guessing its tranny fluid from your 8K SST.
Old May 24, 2012 | 06:18 AM
Kracka's Avatar
That's most likely Diamond ATF SP3 fluid...looks like you unbolted that from your transfer case. You're going to have to refill and bleed your S-AWC hydraulic system before driving the car.
Old May 24, 2012 | 07:02 AM
Registered User
Thank you guys! It is transmission oil. People recommended me to refill with Mitsu Diaqueen. Thank you so much!
Old May 24, 2012 | 11:27 AM
Struc's Avatar
It's ATF from your S-AWC system, not actual transmission fluid for this car.
DO NOT PUT THAT IN YOUR TRANSMISSION.
Old May 24, 2012 | 08:30 PM
ChiefMak's Avatar
+1, and SSTF-1 is green.
Old Jun 1, 2012 | 02:08 AM
Epicfa1l's Avatar
How did you happen to accomplish that?
Old Jun 3, 2012 | 11:29 PM
23tuner's Avatar
hello I hope I can be of some help, That is the clutch mechanism area of the transfer case on your evo.
Actually pretty easy to get to and make this mistake, NOt to bad though.
also I hope you have gotten it taken care of since it happened, but if not I hope I can shed some light on the fix.
MAke sure that there is 2 copper washer that on either side of the banjo bolt line end( round hole on the oil line.) one on the case and one on the head of the bolt
Re-install the banjo Bolt making sure not to cross thread it. that area is a little tricky to reach if my memory is correct. once finger tight, tighten only slightly, it takes a little skill to feel what is too much with the Transfer case in the car.
next go to the trunk(boot) and look on the right side of the cargo area and you will see a little door inside will be a reservoir filled with red fluid. that is the reservoir for the ACD. Sorry I cant remember what its designation is. just follow the the next step it will get you the right fluid, its important to get the right stuff, but not important to memorize all the part numbers for all the factory fluids
Go to the dealer and ask for a quart of fluid for the ACD, its the same for the 8-9 or X but special to Mitsubishi. actually the X might have a new fluid but I have used the 8-9 fluid, I cant remember exactly
This next part is the tuff part. Bleeding the ACD system of air that was introduced when the line was opened and the fluid leaked out, But very important, and can cause damage to the clutch and pump
you need to do one of three following things, I have use all three and they all work. but dont drive the car if at all possible untill this process is performed.
1) find someone with a MUT 3 AND that know how to use it and have them bleed the ACD clutch
2) find someone that has a break out box for the ACD and bleed the clutch.
3) I have used this process in a pinch(at a Rally on my own RA) but it is on you Im only trying to get you back on the road with little drama
ok fill the ACD Res in the trunk, hook a hand vacuum pump(the big 5QT ones) to the bleeder on the bottom side of the Transfer case on the bottom of the ACD clutch piston area. next apply very little vacuum one maybe 2 pumps. next crack the line slowly until fluid starts to move, nothing more. next another person might help here. as you are watching the bleeder have a friend watch the Res. and fill it back up to the full line as the fluid level drops to the low line. do not let it go below that. just to be safe thats all. once that happens a couple of times you should be good.
Again I am only trying to help It has been about a year since I was working on these cars and Im sure some out there will tear this reply apart, but I have used all three ways personally and they all work. But I recommend getting it to a shop that has a MUT 3 to do it properly.
I am not a "know it all" I invite anyone to add or take away anything I said or recommended. But I do have a significant amount of experience racing and building these cars.
Hope you get it fixed
hope this helps a little
Old Jun 7, 2012 | 12:55 AM
jayeeyee's Avatar
That is transmission oil.. replace the crush washer too when you put it back on.
iceman7
14
Aug 21, 2012 11:13 AM
Jehuty
Nov 6, 2011 03:43 PM
exhil
Apr 29, 2011 10:41 PM
raytrix
Apr 23, 2011 09:44 AM
DeeezNuuuts83
For Sale - Wheels / Tires
Oct 21, 2009 02:20 PM
