How to: Delete Spare tire using Styrofoam craft supplies.
Parts required: Styrofoam for making wreathes. Commonly found at craft shops like Michael's. Roughly you will need enough rings to make a height of about 6.5 inches.I used 3 rings that were 1-15/16ths thick and 1 solid disk that was just 15/16ths thick.
Tools required : Caulk gun if using my method of gluing things together.
Number of people : 1
Difficulty : 2. Simply because it is more difficult that installing floor mats.
Time to complete 10-15 minutes.
Step 1 : Glue the rings together and disk together using a glue that is safe for foam board. Can be found at Home Depot or Lowe's.
Step 2 : Remove rear trunk cover Jack, tire wrench and spare tire.
Step 3 : Remove the two foam pads. The one I'm pointing to as well as tje on directly to it's 6 o'clock.
Step 4 : Set the "trunk-tire" spacer in the center of the vacant space. You can choose to glue it down, but I just left if free. I will update if it shifts too much. Then reinstall everything in the same order that you removed it.
Thanks!
-Jeff
Thanks!
-Jeff
So here's a dumb question: why bother with all this and not just take out the cardboard false floor? That way you gain a huge amount of trunk space and might actually be able to fit a dead body or two in there.
FYI, this may actually be dangerous to do.
As I understand the spare works with the car frame in the event of rear end collision as a structural support to help slow the car crashing into you.
Just figured I would post this here.
In any case, I have since removed everything and filled the area where the spare was with foam and laid down the board an carpet on top of it. Gained about 5" in height..
I never consider collisions when I do anything.
