Evo X How Tos / Installations Post or link to your detailed how to / installation articles in here. If you have any questions regarding the how tos, feel free to post them in the Request sub-forum.
Fluid help
Old Jul 31, 2014 | 12:51 PM
07chuck's Avatar
Fluid help
2010 mrt with the auto sst trans.
bought it with 85k miles with no service history so*
just correct me if I'm wrong please bear in mind I have not even removed the underpan yet.
From what I researched so far this is what I come up with.
Oil change completed
Buying new plugs soon ( research not done )
bought 2 gallons of SST fluid and a filter
I need 1 quart of 90w lsd and 1 quart of mitsu Atf to service the rear end ?
Front t-case and diff and integrated into the tranny (share the sst fluid)
Flushing coolant/brake fluid
Am I on the right track here ? Did I forget something?
Old Aug 11, 2014 | 03:09 PM
ikt's Avatar
ikt
The SST will need reset after fluid changes I believe. I know the dealership I go to only charges about $80 to drain, fill, and reset. That way you get a labor warranty on the work.
The read diff is ATF on one side, and gear oil on the other. I would also just have the dealership do it. Not worth the minimal money saved for the risk of a massive, massive repair bill. If you do it yourself, make sure the car is perfectly level as well.
Old Aug 20, 2014 | 02:38 PM
boostedlife's Avatar
I haven't heard of the 'reset' on the SST before, just drain/fill or flush. I was planning on doing mine myself (fluid/filter purchased already) but $80 is not bad if the closest dealership here offers anything close to that I might consider it.
Old Aug 22, 2014 | 06:47 PM
deanob's Avatar
You almost got it,
-SST Diaqueen + Filter for Trans
-ATF for Rear AYC Pump (flushed on right side of rear diff-- look for markings)
-Diaqueen Gear Oil for Front Diff and Center Diff
amir008
Mitsubishi TC-SST Discussion
231
Feb 27, 2017 02:32 AM
BeyondLimitsEvo
17
Jun 5, 2015 03:18 PM
Evol Darwin
Nov 28, 2014 12:48 AM
apexbeast
May 3, 2014 06:08 AM
Piper747
75
May 24, 2012 06:12 PM
