Transmission Fluid Change.
Who has done one on there X?
How much fluid do you need? What did you use for replacement fluid? |
I've done it. It was really easy. I went with AMSoil. I forgot the amount but The Doc knows and it tells you in the book. I suggest ordering a fluid pump it was the saving grace. The bolt is by the driver side wheel. It's simple.
Just attach a hose to a funnel and position it in the engine bay. No pump needed.
I got Redline MTF, letting the car cool down a wee bit. I ran her hard.
Redline MT90, no more grinding.
Originally Posted by TTP Engineering
(Post 6012320)
Looks like I made the wrong decision... Should I flush it out and put in the MT90? |
Originally Posted by Keepster13
(Post 6009090)
3 qts is enough to do the transmission. I always goe with the AMSOIL MTG for the EVO. And yes, for $9.95, that pump makes the job very easy, and it screws right on top of the AMSOIL Qts, Half Gallon, Gallon and even the 2.5 gallon jugs, then you have the pump for when you are ready to do the TC and Diff as well. Doc |
Originally Posted by Oil Doc
(Post 6012478)
Thanks !!
Originally Posted by BlackTrack
(Post 6012508)
I use MTG in my trans as well! What do you suggest we use for the Tcase and Diff in our X's?
Can't beat the AMSOIL MTG in the tranny !!! Have had great responses from people. SVG is the Top of The Line Fluid for the TC and Diff.. 2 qts will cover both.. Thanks, Doc |
I swapped the tranny out to Redline MTL (and like so far) and I'm running the 75w90 redline in the diffs-I;ve really liked that so far.
Plus, the package deal from Redline cant be beat (imho)- |
Originally Posted by 08EvoXGSR
(Post 6012547)
Plus, the package deal from Redline cant be beat (imho)- For the tranny, directly from Redline themselves, they suggested running two quarts of MTL and one quart of MT90. That brings it close to the 75W80 the manual suggests. |
(Post 6012478)
Thanks !!
(Post 6012547)
Originally Posted by Thegame
(Post 6012573)
I hope whatever you're running in the diff's is a GL5 hypoid gear oil. The only thing I would use in the transfer case would be the stock fluid or Redline Heavy Shockproof.
AMSOIL SVG is unbeatable ... Shockproof is not recommended... It is a petroleum based product and has shown to have paraffin buildup. For the tranny, directly from Redline themselves, they suggested running two quarts of MTL and one quart of MT90. That brings it close to the 75W80 the manual suggests. If you are a Daily Driver and do not abuse the car at all, AMSOIL MTF is the correct fluid (meets or Exceeds OEM Specs)... If you run the car hard (99.9 % of EVO Owners) AMSOIL MTG is the fluid of choice. Doc |
Okay, so it foams a little....and it breaks down faster.....and it clumps.
I'll change it this weekend....thanks! |
Originally Posted by Talon_66
(Post 6008064)
How much fluid do you need? What did you use for replacement fluid? I made a fluid bomb pump out of a washer bottle works great. will post some pics later.. lol |
