Transmission Fluid Change.
I've done it. It was really easy. I went with AMSoil. I forgot the amount but The Doc knows and it tells you in the book. I suggest ordering a fluid pump it was the saving grace. The bolt is by the driver side wheel. It's simple.
3 qts is enough to do the transmission. I always goe with the AMSOIL MTG for the EVO.
And yes, for $9.95, that pump makes the job very easy, and it screws right on top of the AMSOIL Qts, Half Gallon, Gallon and even the 2.5 gallon jugs, then you have the pump for when you are ready to do the TC and Diff as well.
Doc
Thanks !!
Doc
Doc
I swapped the tranny out to Redline MTL (and like so far) and I'm running the 75w90 redline in the diffs-I;ve really liked that so far.
Plus, the package deal from Redline cant be beat (imho)-
For the tranny, directly from Redline themselves, they suggested running two quarts of MTL and one quart of MT90. That brings it close to the 75W80 the manual suggests.
Thanks !!
Doc
Doc
I hope whatever you're running in the diff's is a GL5 hypoid gear oil. The only thing I would use in the transfer case would be the stock fluid or Redline Heavy Shockproof.
AMSOIL SVG is unbeatable ... Shockproof is not recommended... It is a petroleum based product and has shown to have paraffin buildup.
If you are a Daily Driver and do not abuse the car at all, AMSOIL MTF is the correct fluid (meets or Exceeds OEM Specs)... If you run the car hard (99.9 % of EVO Owners) AMSOIL MTG is the fluid of choice.
Doc
I made a fluid bomb pump out of a washer bottle works great. will post some pics later.. lol
