o2 fix?
What can i use to turn off the CEL light after installing a test pipe? Is it worth picking up the AMS o2 fix? has anyone used that and not worked? the warning light isnt a big deal, but it just gets annoying at times.
Either patch it out in your ecu, or run 2 spark plug antifoulers that can be found at autozone for a few dollars. Just have to drill out one of the antifoulers, screw it on your o2 sensor, and screw the un-molested one on the very end. :)
Yeah, ECUFlash can get rid of a lot of them now, see here:
https://www.evolutionm.net/forums/ev...p1238-etc.html FWIW, I ran every single different type of o2 spacer with my test pipe, and none worked. The L Shaped one, the normal spacers, none of them prevented, eventually, a CEL from coming on. YMMV, of course. |
Originally Posted by hotdog
(Post 8029649)
https://www.evolutionm.net/forums/ev...p1238-etc.html FWIW, I ran every single different type of o2 spacer with my test pipe, and none worked. The L Shaped one, the normal spacers, none of them prevented, eventually, a CEL from coming on. YMMV, of course. Patching it out is a way better option!:D |
I accidentally posted this thread with my wrong account. but thanks a lot. ill definitely look into the antifouler fix. so i guess if that doesnt work i can try the ecu fix. A local shop mentioned to me that theres going to be a for sure ecu fix in a month and for me to just come in to get it flashed if its still coming on. because the previous ecu fixes caused other codes to pop up.
if you don't want or do not know how to patch the ecu, try adding some steel wool. heard it works. GL ;)
Originally Posted by villero1834
(Post 8033553)
i wouldn f==k with the ecu
