Perrin DP/HFC doesn't fit. Turn it into just HFC?
Hey guys,
I bought a Perrin DP/HFC combo, and when I went to install it, it didn't fit. There was no bowl taper to fit the OEM donut gasket, and the flange was too thick to thread the spring bolts. I picked up an AMS DP locally and installed that piece instead. My question is should I cut the DP part off and use it as a HFC? What flange should I use? How much should it cost to get in welded on? I found this . . . http://vibrantperformance.com/catalo...roducts_id=144 Pics btw, OEM w/ gasket http://i162.photobucket.com/albums/t...IMAG0006-1.jpg Perrin w/ gasket http://i162.photobucket.com/albums/t...IMAG0004-1.jpg Showing differences in OEM v Perrin taper http://i162.photobucket.com/albums/t...y/IMAG0003.jpg |
I had to cut the springs on my HM DP/HFC because of the thickness of the flange. It works perfect now. I am not sure about the donut gasket problem... I would probably just sell it now that you have the AMS and just use the money to buy a HFC.
Unlike Perrin, I don't want to sell something that is going to give someone a problem. I could bring it to a machine shop and grind down the flange and further grind down the gasket to make it fit for someone (as I have the OEM O2 housing off the car), but I don't want to misrepresent a part.
Have you tried contacting Perrin? Plenty of people run their stuff w/o issue.
Yeah I did. I didn't purchase from them and I didn't save the receipt. Their air filter didn't fit either, and they were very nice about it, but they wouldn't help me on this without a receipt, even though they admit it was incorrect. This is despite the fact I did buy their turbo inlet and my Cobb AP directly from them.
A few local guys I've met warned me about their stuff not always fitting, like their intercoolers, but I have no 1st hand experience with that. It's a shame because they seem like great guys, and if I did buy direct, I probably wouldn't have a problem exchanging anything. |
Their intercoolers fit great; I had one on my IX and helped a local install one on his X.
It looks like the Perrin DP is designed to bolt up to the Turbo Adapter (O2) without the doughnut. You would use a flat gasket and instead of the spring-loaded bolts, tighten it hard. But, unless there is a flex section lower down, engine movement would be carried into the exhaust.
Originally Posted by lowkey
(Post 9122459)
I wonder if I cut that end off if I can unweld that flange and reweld it lower instead of buying another $25 vibrant flange. Either way, any idea of how much a shop should charge to weld on a new one? |
Hey,
I had the exact same problem with mine so I just cut about 1/8"-1/4" off the back end of the doughnut gasket and that sorted it out. Since I was a little nervous about cutting it I bought a replacement just in case (they are about $15 from fred bean). Not there is a metal mesh that runs through the graphite so it can be a bit hard to cut, we put it in a table vice and used a reciprocating saw, I'm sure a hacksaw would work but I imagine it would take a minute. Hope this help |
Originally Posted by damienfs
(Post 9154829)
Hey,
| All times are GMT -7. The time now is 09:23 AM. |
