aem 30-0300 x series install help
1 Attachment(s)
hi recently bought this unit and installed in the basics. now i want to log using evoscan .
how can i do it without the serial port this thing has too many extra wires all i wanna know is how can i get this to work with evo scan on my evo x 2008 https://www.evolutionm.net/forums/at...p-untitled.jpg |
You have to use the Serial Output. You can either make one, or buy the Spec-Ops harness from STM. If you're computer doesn't have a serial connection, you'll also need a Serial to USB adapter.
is there no other way like going direct i know about the serial but was hoping i could get a better option than a lot of hanging wires around the dashboard
Originally Posted by night crawler
(Post 11572754)
I mounted my guage on the steering wheel for now but I am working on a cus tom center panel where I will place the guage and the panel will also hold a sliding 10 inch iPad and I will use the side of the panel to hold all the plug ins like an extended obd and will have to now place the serial socket next to the obd I will post a design once I get back home
can anybody update me on what port settings should i keep for the uego x series? currently its on 9600 havent tested it yet
But how do you get it to work with evoscan? :)
Edit: Blegh this is what you get for using your mobile phone, I had jumped down to mapperformance bumping a thread about this under this one and hit reply. Figures it went to the original thread. Sorry for grave digging this. |
