aem 30-0300 x series install help
hi recently bought this unit and installed in the basics. now i want to log using evoscan .
how can i do it without the serial port this thing has too many extra wires
all i wanna know is how can i get this to work with evo scan on my evo x 2008
How do you have your gauge mounted? You should have your power and ground routed to under the dash. I would then run the serial cable across to the glove box. That way, when you need to log, you just pull it out and have your laptop on the passengers seat. Atleast that's how I have mine ran, but both my gauges are mounted on my A-Pillar.
I mounted my guage on the steering wheel for now but I am working on a cus tom center panel where I will place the guage and the panel will also hold a sliding 10 inch iPad and I will use the side of the panel to hold all the plug ins like an extended obd and will have to now place the serial socket next to the obd I will post a design once I get back home
But how do you get it to work with evoscan?
Edit: Blegh this is what you get for using your mobile phone, I had jumped down to mapperformance bumping a thread about this under this one and hit reply. Figures it went to the original thread. Sorry for grave digging this.
FS[MidWest]: AEM X-series wideband 30-0300 (USED 1 month)
blancoloco
Oct 29, 2016 07:34 AM
Johnboy1065
Jul 22, 2012 11:16 PM
