Ulitmate DIY Transfer case, TC-SST Transmission and Rear Differential fuild change.
Transfer case, TC-SST Transmission and Rear Differential drain bolt/fill up location
If the service manual is unclear for some of you. Here are pictures of the drain bolts and fill up hole location for front Transfer Case, TC-SST MR transmission and Rear Differential. Brand fluids is up to you.
Front Transfer Case.
TC-SST Mr Transmission only.
TC-SST Mr Transmission fill up hole.
Located on top, underneath the air filter box which will require removal.
Rear Differential drain bolt. Labeled gear oil with arrow. "Big Bolt"
Rear Differentiall Fill up hole. Labeled Gear oil with arrow.
" Bolt is facing toward front of vehicle"
EvoM Community Team
Since its not pictured.....
For the ATF rear diff fill it is *NOT* the bolt pointing toward the rear that looks just like the fill bolt for the gear oil (that points forward). You have to go over the rear crossmember to see it and it is right in the center of the diff.
If it looks like a mounting bolt, it probably is.
