Blacktop Aero CF lip
Super easy. Even a caveman could do it. Wrench 10mm socket, drill, self tapping black screws, plastic black washers. 1 on scale 1-10. Easy like Sunday morning!
how many bolts did you put? i just got mine today and i just saw 4 holes for the bolts(2 for the metal holder and 2 underneath the carbon and double sided tape).what happened on the screw on side the one that facing the wheel?how many screws do you have to remove on the factory sss aero to remove it?
^yours will be a little bit more involved than us without the OEM aero kit.
https://www.evolutionm.net/forums/ev...tructions.html
from what i have gathered from td66. you use the bronze screw for the 2 front brackets and the 2 black screws goes on the bottome edge of the lip. also from what he told me, he thinks its "overkill" to actually put the screws on the bottom edge corner as the 2 front screws and double adhesive are sufficient to hold the lip. lastly he mentioned that the lip somewhat "snaps" onto place as you push it inward.
pls correct me td66 if my statement is false.
Looks good. I would love to see what this lip would look like with the section below the fogs painted to match the car, keeping the bottom in CF so it looks more like a bumper with a front carbon splitter.
Bet that would look nice! Those fog lights are going-going-gone this summer!
