Which of the two??
Old Feb 23, 2009 | 09:45 PM
stikllr13's Avatar
Which of the two??
So I am literally torn between these two wheels.
What do you think I should go with? I have a GG evo x and I will be getting either of these sets in flat black and both are 18X9.5 +20 (Could only find a pic of flat black for the DPT's).
Let me know!
Thanks guys
Old Feb 23, 2009 | 09:52 PM
Astro_Train's Avatar
Veteran: Navy
the Grids are have a very aggressive concave face as oppossed to the DPTs. Also... I believe the DPTs in the 18x9.5 will come in +35 as opposed to the Grids in +20. Which means that the Grids will stick out alot further than the DPTs. PM Dan at Wheeldude and see what he says on the DPT's offset as this will make a difference on how the wheels will look. I say go with the Grids as they look more aggressive.
Old Feb 23, 2009 | 09:57 PM
EViTZO's Avatar
I love the look of the DPTs on Evos... but that's just my oppinion
Old Feb 23, 2009 | 10:02 PM
stikllr13's Avatar
Yea I just got a PM from Dan and all the info he gave me was that next month the DPT's will be available for the X. If you are right and its only a +35 offset then it's a done deal I will go with the grids. But if they are +20 then both are tempting
Old Feb 23, 2009 | 10:51 PM
gtrskyline34's Avatar
i wish the DPT's come in +20's
Old Feb 23, 2009 | 10:54 PM
ScottSpeed21's Avatar
I would get the Grids if I was me, they're better looking and have a more aggresive concave face.
Old Feb 24, 2009 | 02:08 AM
wickedchimp's Avatar
Grids are played out. Be original
Old Feb 24, 2009 | 04:20 AM
markg1018's Avatar
Grids FTW!
Old Feb 24, 2009 | 08:34 AM
Veteran: Navy
I wonder why they decided to make the DPTs in such a conservative offset... I guess they will look fine on a IX but on a X with a +35 offset, they will be sitting inside the wheelwell. You have one option that can still work if you prefer the DPTs.
Just use spacers with longer studs.
If you go with a 10mm spacer and longer studs, then you will be running the DPTs in a +25 which will put them closer to TE37s or the Grids offset and they will look better than sitting inside the wheelwell..
Use spacers for the DPTs and you will much happier with the looks. I guarantee the +35 will look a bit funny on the X so most people will probably be using spacers to make them stick out a bit more.
I had the same issue when I bough a set of CE28s as the concave face only comes in the ultra low offset of +22 or +15... but the +22 CE does not clear the brembos so I had to do alot more modding to the rear fenders and run negative camber to make them look more tucked in. The +15 on a X would look killer tho but on a IX you need to do some work so they don't look stoopid sticking way out.
Anyways man I think if you go with some good spacers you will much happier with the results. The DPT is basically the CE28 in looks so no doubt they will look killer on a X. Just look at Archie's X that is running 19x10.5 +22 Ce28s. Its insane looking.
Old Feb 24, 2009 | 08:57 AM
boostin20's Avatar
The grids are tooo sexy!
Old Feb 24, 2009 | 09:34 AM
veightkiller's Avatar
the Grids are easier to clean than the DPT's no doubt about that but i'd choose the DPT's goodluck bro!
Old Feb 24, 2009 | 10:30 AM
stikllr13's Avatar
Thanks guys
I think I am leaning towards one now.
Old Feb 24, 2009 | 10:39 AM
hameedosh's Avatar
1st
Old Feb 24, 2009 | 11:53 AM
impreza_punk's Avatar
Personally I'd pick the DPTs, plus if they are gonna be flat black you wouldn't have to be as meticulous as far as cleaning goes.
Old Feb 24, 2009 | 01:10 PM
flyboytb's Avatar
Grids (if I had to buy rota)
