De badged trunk, painted engine bay and some CF bits.
Old Jul 22, 2009 | 03:04 PM
Lobster's Avatar
Lookin' good!
I like the uniform look under the hood. I think it cleans things up nicely.
Tho i do agree with the other people who prefer the matte/flat finish.
Props for doing something different!
Old Jul 22, 2009 | 03:07 PM
bluegsr's Avatar
the reason why i dont like the engine cover is becouse it LOOKS like it was spray painted. thats a no go. sand it down, and paint it flat black! everything else looks great.
Old Jul 22, 2009 | 03:10 PM
imdrew12's Avatar
Sand down a piece of plastic? What grit?
Old Jul 23, 2009 | 07:31 AM
geezevox's Avatar
Sand it with 400 grit. Use a bucket of water to keep the sandpaper from getting clogged. Dip in water, sand, rinse, repeat. You just want the surface ruffed up a little so the paint will stick better. Also, it looked like you had a tiny bit of orange peel (the wavy look) where you sprayed. The sanding will help prevent that because the paint sticks better.
You don't have to go crazy with the sanding, just make sure the whole surface has a uniform sanded look.
Old Jul 23, 2009 | 09:40 AM
jgoddy77's Avatar
look better
Old Jul 23, 2009 | 09:42 AM
imdrew12's Avatar
Originally Posted by jgoddy77
look better
Thanks
Old Jul 23, 2009 | 09:43 AM
imdrew12's Avatar
Do you think Plasti-Dip will work?
Old Jul 23, 2009 | 09:49 AM
MR.Wicked's Avatar
nice mods, I have always hated how that cover looks stock.
Old Jul 24, 2009 | 12:12 PM
geezevox's Avatar
Never used it, but heard it is good. You just want the surface as uniform as possible before you start...even if you are going to use the plastic dip.
I know the plastic dip is tough and will withstand the heat. It may peel unless you sprayed/dipped the inside of the panel as well. If you are going to go that route, I would spray a band around both the front and the back to help against peeling.
Old Jul 24, 2009 | 02:06 PM
ImsoevoX's Avatar
First off let me just say, awesome color! I like PB wish I had one. I like what you did with the emblems..but I agree..you might want to do flat black as oppose to gloss. It looks kinda weird. In one angle it looks good, but that pic where it's right on top doesn't look so great in IMO. Looks like you put in some work. Good luck with whatever you decide
Old Jul 24, 2009 | 05:26 PM
AWDTerror's Avatar
Originally Posted by Silver06evo9mr
the black needs to be less glossy. redo it. the cf bits are made by who? the weave looks terrible. A for effort tho
The weave looks bad because of the flash from the camera.
Old Jul 25, 2009 | 01:59 PM
imdrew12's Avatar
Oh
I have been trying to get a hold of you. I lost your # and was wondering if you would like to get together
Old Jul 25, 2009 | 02:22 PM
ImEv0's Avatar
your engine cover looks weird.
Old Jul 25, 2009 | 02:33 PM
imdrew12's Avatar
Yes I know, its been said.
Old Jul 26, 2009 | 12:13 PM
imdrew12's Avatar
Better?
