Trunk dampner for Evo X??
Old Dec 15, 2009 | 05:54 PM
Massappeal's Avatar
Hi, does anyone know if the Lancers have a trunk dampner and if its less stiff as the Evo X ones, since they come wingless from the factory?
Reason for asking is I plan on doing the Do luck trunk and the OEM ones like to shoot the trunk up fast and also harder to close when the Wing is not there anymore. (yes I am that picky)
Old Dec 15, 2009 | 07:59 PM
robevo8's Avatar
its not picky... my buddies STI has no big spoiler either and when you open the trunk...WHAAAM it flings up and im scared its gonna go further one day and take out his back window... haha... so id try and find a new damper too.
Old Dec 15, 2009 | 08:01 PM
1GGEvo's Avatar
my do luck would appreciate this too
Old Dec 16, 2009 | 09:32 AM
atombomb33's Avatar
EvoM Community Team
I had similar issues back when I had my Evo IX and took the wing off. Scared the poop out of me the first time I popped the trunk and it slammed open.
I have not heard of any aftermarket dampeners for the trunk (only for the hood). I guess the stock Lancer ones might work, but I can't confirm if they are any less stiff.
Old Dec 17, 2009 | 04:30 AM
aftershock141's Avatar
I took my OEM one's off. It felt like they were placing too much pressure on the trunk. The trunk stays open fine without them. Just don't leave it open on windy days.
Old Dec 17, 2009 | 11:39 AM
Golden's Avatar
Can you take one off and leave the other one on?
Old Dec 17, 2009 | 04:34 PM
That would put stress on only one side when closing the trunk. The DoLuck is so light and thin that I wouldn't even chance it. I never really use my trunk anyway. Its stripped. How many of you do?
Old Dec 17, 2009 | 04:41 PM
LVSBB6's Avatar
Is there any replacement dampeners that are shorter in length than stock?
Reason being my rear spoiler is touching the rear glass at fully open, so I have to be very careful.
Old Dec 17, 2009 | 04:56 PM
[Neo]'s Avatar
aftermarket spoiler? it should hit if its OEM
Old Dec 17, 2009 | 10:59 PM
brads09lancerGT's Avatar
You can go to your local auto parts store, almost every decent size auto parts store sells them in lots of different lengths and gas power I guess u could say. The stock ones are 280N.
LVSBB6 I've seen them at Lordco, they can order in pretty much any lenght and power that is available.
Old Dec 17, 2009 | 11:13 PM
LVSBB6's Avatar
Thanks for your input! I found one that fits perfectly with shorter length that does the job
Old Dec 18, 2009 | 09:15 AM
Webman's Avatar
Not to be a grammar ****, but there is no such thing as a "dampener". The proper term is "damper". While a damper does damp or dampen, it isn't a dampener.
Old Dec 18, 2009 | 09:51 AM
Girodisc Martin's Avatar
Hey I know this has nothing to do with the OP but if you want to fix your friends trunk you can take the tension bars that the trunk uses and bend them back a little to reduce their tension. It will make your trunk open nice an smooth. I have done it to many of my friends STis that have swapped to wingless or a carbon trunk.
Johann @ Girodisc
On the OP aren't there dampers on ether side of the EVO X Trunk. I use to have hood dampers on my hood of my WRX wagon and when I swapped to carbon I just took one off and it was perfect. Our trunk is steal so we left both on but I bet taking one off would do the trick.
Old Dec 18, 2009 | 11:01 AM
07outty's Avatar
dampener is a word in the english language. it is a noun.
it is a device which dampens movment or vibration.
Old Dec 18, 2009 | 05:40 PM
1GGEvo's Avatar
Webman, i think you deserve one of these for not doing basic research
