My X build Differnt in a few ways!
before you get the ams 02 fix, consider this... they are using the vibrant spacer, which is similar in most aspects to the basic spark plug anti-fouler setup a lot of people try using, and can be hit-or-miss a lot of the time depending on what mods you have and such, often requiring 2 or 3 spacers to get the light to stay off. check this out first:
http://cgi.ebay.com/ebaymotors/ws/eB...m=140384280083
its got a 90 degree bend and depending on flow numbers and sensor response, you can position the bend facing upstream or downstream to meet your needs. shipped, its only 5 bucks more than the ams unit. i got this instead of the traditional straight spacer and havent looked back, no cels whatsoever on a full 3" turboback with test-pipe and some other mods on the intake side of the engine. just something else to consider
I will keep looking into it and maybe just get it tuned out eventually if it doesnt work. Thanks
I have a Vibrant 02 spacer, along with a heat wrapped test pipe with a Cobb AP stage 2 flash and I haven't had a single o2 code since I flashed stage 2 (~7k miles). Heat wrap + o2 spacer = no problem.
