Painting stock IC?
Old Mar 4, 2010 | 10:06 AM
imdrew12's Avatar
Painting stock IC?
I would like to paint my stock intercooler black. Will it hurt the performance of the ic and what kind of paint should I use? Also, has anybody done this before? I did do a search and the last thread on the topic is 3 years old so I thought I would start a new one for the X.
Thanks
Old Mar 4, 2010 | 10:09 AM
imdrew12's Avatar
Like this.
Old Mar 4, 2010 | 10:11 AM
Evo a Mula's Avatar
you cant just paint it with regular paint it hurts performace call ets and ask them how they paint theres
Old Mar 4, 2010 | 10:21 AM
mump's Avatar
Do not paint the ic with regular spray paint....I did on my VIII, it chips so easy. After a couple months, it looks horrible.
Old Mar 4, 2010 | 10:26 AM
CoachG's Avatar
Either anodize or get a thermal coating (like Swain BBE) so the efficiency of the IC is either not negatively effected (or helped with the BBE).
Old Mar 4, 2010 | 10:37 AM
imdrew12's Avatar
Hmmm.....http://www.amazon.com/HIGH-HEAT-BLAC.../dp/B000B6DG6S
You are viewing Dupli-Color High Heat Engine Paint - BLACK . Duplicolor High Heat Paint with Ceramic is formulated for high temperature paint applications. Exclusive durable Ceramic formula increases heat dispersion to maintain & protect paint's original finish. Developed and tested in the lab, this high-heat paint will perform up to the most rigorous standards of racing and street rod enthusiasts. Ceramic resins provide protection from exposure to excessive heat and automotive fluids. Resists oil, gas, grease, rust, salt, humidity, and solvents  and temperatures up to 1200°F, intermittently. With EZ Touch nozzle. Price shown is for one 12 oz. can.
Old Mar 4, 2010 | 10:39 AM
hammilljr's Avatar
ETS anodizes theirs!
Old Mar 4, 2010 | 10:52 AM
imdrew12's Avatar
You guys have to realize, that while those would be ideal ways to change the color of an IC, I live in the middle of no where. There just aren't places near by that do things like that. I would probably have to travel over 130 miles for any kind of service like this. All this in account makes painting all the better.
Old Mar 4, 2010 | 11:11 AM
evolvedx's Avatar
First, you search poorly. This has been covered before:
https://www.evolutionm.net/forums/ev...heir-fmic.html
https://www.evolutionm.net/forums/ev...tercooler.html
Second, this is a terrible idea.
Third, your example pic of the Perrin IC is not painted, they anodize theirs...
Old Mar 4, 2010 | 11:26 AM
ct78155's Avatar
There is alot of debate regarding this topic.
Will painting it make you lose 100hp? No.
I honestly don't think it will have much effect performance wise, and if it does it will be so small that it really won't matter.
You have to keep in mind that you would just be painting the "face" of the intercooler.
There are fins that run horizontal all across your intercooler core.
http://himni-racing.com/images/inter...20core%202.jpg
Other options would be anodizing, which "stains" the metal to change the color.
Also, there is a heat dissipation coating which will actually increase the efficiency of your intercooler.
Old Mar 4, 2010 | 11:30 AM
imdrew12's Avatar
Evidence for terrible idea?
Old Mar 4, 2010 | 11:50 AM
evolvedx's Avatar
...is contained in a heat transfer analysis.
Old Mar 4, 2010 | 11:55 AM
imdrew12's Avatar
From an Automotive Engineering site.
http://www.eng-tips.com/viewthread.c...=98349&page=10
Old Mar 4, 2010 | 12:06 PM
evolvedx's Avatar
^ not an "automotive engineering site" (its actually just an engineering forum), but it gets the point across.
Sidenote: I'm a structures/thermal engineer.
Old Mar 4, 2010 | 12:15 PM
pfunk47's Avatar
I painted mine flat black, no clear. You will notice no performance degradation based of a couple thousandths of a mil on a DD, on a track car your going to reach heat soak faster because you've added a small thermal blanket from the paint which in turn you'll lose some HP. Your also only painting the exterior so the fins the air passes through are still bare. You can always use a wire brush with a drill to take it off and make it look brand new if you want to go back.
