Official: Volk/Rays/Gram Lights wheels thread (Evo X only)
Subscribe
Mar 13, 2013 | 12:25 PM
  #241
from this past weekend...@ Cobb SoCal
Reply 0
Mar 21, 2013 | 05:00 PM
  #242
Quote: He might be better off going with a 265 though because the +15 is very aggressive. It's stretched a bit. That why I went with +22. I wanted a beefy tire
I say go with the 275's (pic below)....265's are a bit stretched. All depends on how much camber you'll be running to provide fender clearance.
I'm on 18x10.5 +15
Reply 0
Mar 23, 2013 | 04:13 AM
  #243
Hey guys any once can give me advice on how to stick the volk racing on my te37sl without bubbles? I've tried one rim so far and major bubbles. Even tried a heat gun to even out and no luck.
Reply 0
Mar 23, 2013 | 06:58 AM
  #244
Use water in a spray bottle. Lightly coat the wheel, and lightly coat the sticker. Start from one side and rub the water out until the sticker is applied. Then after that take a hair dryer to it to make sure it's completely adhered.
The water layer helps undo any mistakes that get in there.
Reply 0
Mar 23, 2013 | 09:45 AM
  #245
Quote: Use water in a spray bottle. Lightly coat the wheel, and lightly coat the sticker. Start from one side and rub the water out until the sticker is applied. Then after that take a hair dryer to it to make sure it's completely adhered.
Agreed. U can also use a water squeegee or any hard plastic card to push out the water bubbles.
Reply 0
Mar 23, 2013 | 11:23 AM
  #246
was bored... Volk bros.
Reply 0
Mar 24, 2013 | 11:33 PM
  #247
18x11 +18 here. camber at -2.5 front -1.5 rear. tires 275/35 RS3
Reply 0
Mar 25, 2013 | 04:29 PM
  #248
Quote: No cracked paint? good job I'm gonna do mine as well.. need to buy a roller.
No. Just that stupid painted foam strip was a victim. I don't know how you can avoid it
Reply 0
Mar 25, 2013 | 06:36 PM
  #249
Quote: No. Just that stupid painted foam strip was a victim. I don't know how you can avoid it
that foam strip is actually seam sealer that has been painted over. if you remove it or if its cracked, you should have a body shop replace it. last thing you would want is rust.
Reply 0
Mar 25, 2013 | 07:48 PM
  #250
I made a video that explains how to do the fenders pretty well if you need to stop your rubbing.
ps. sorry about the door chime. We forgot to close it
Reply 0
Mar 25, 2013 | 07:54 PM
  #251
Undercoating spray worked great.
Quote: that foam strip is actually seam sealer that has been painted over. if you remove it or if its cracked, you should have a body shop replace it. last thing you would want is rust.
Reply 0
Mar 26, 2013 | 02:30 AM
  #252
new purchase
Reply 0
Mar 26, 2013 | 10:14 PM
  #253
My turn:
18x9.5 +22 LE37 with 265/35/18 potenza re760
Yes, it needs a drop bad - gtworx springs comings soon.
blue work rs-r lugs for sale. Black Rays extended will be on next week.
Reply 0
Mar 27, 2013 | 12:31 PM
  #254
Quote: yes those are real le37's.
Thank you. Yes real volks.
This was before they stamped all around the front edges.
Reply 0
Mar 27, 2013 | 04:50 PM
  #255
Quote: Undercoating spray worked great.
this is exactly what I used. It's impossible to not f up that strip, just hit it with some rubberized undercoating afterwords and you're good to go.
Reply 0
