Official: Volk/Rays/Gram Lights wheels thread (Evo X only)
Old Mar 14, 2011 | 07:13 PM
  #61
EvoX-11's Avatar
Old Mar 16, 2011 | 09:25 PM
  #62
Fishstix's Avatar
Old Mar 18, 2011 | 11:42 PM
  #63
avatar2140's Avatar
Old Mar 28, 2011 | 08:53 AM
  #64
snoar's Avatar
hey avatar2140
did you have those powder coated at Elite Coatings?
I had a set of Advan RS repowdercoated there and saw te37s in the same color there.
Old Mar 28, 2011 | 01:19 PM
  #65
ilestjcollector's Avatar
I have a question. What size/offset can i buy if i dont want to roll my fender? Im planning to get a TE37 SL 18x9.5 +22. can i go 18x10? Thanks in advance.
Ps. Im running eibach pro kit
Old Mar 28, 2011 | 07:29 PM
  #66
lannym's Avatar
All else being equal, i.e. tire size and offset, adding 1/2" to your width is not likely to change wether you rub or not. You'd be adding a 1/4" to the inside and a 1/4" to the outside, but only at the lip, which isn't going to rub anything. It will slightly increase the footprint, but not enough to add more that a mm or two at the edge of the sidewall. So if you're not rubbing at 9.5" then you should be okay at 10".
Now, as far as will that setup rub-it's gonna be tire dependent imo. 275s, probably rub, wide 265s like Star Specs, probably rub too. A narrow 265 should be okay..
Old Mar 28, 2011 | 07:38 PM
  #67
lancerarmstrong's Avatar
here's a question probably nobody has asked yet: with all this crap happening in Japan, would I be able to order a brand new set of CE28s from volk? no i don't want used ones so don't even ask.
Old Mar 28, 2011 | 08:07 PM
  #68
Chebosto's Avatar
Rays Foundary isnt located in the Tsunami affected areas.. You can purchase new Volks no problem. just slightly delayed shipping due to logistical issues with everyone else trying to get goods out of Japan.
Old Apr 5, 2011 | 05:53 PM
  #69
93HardTopTurbo's Avatar
Will the CE28N TA 18x9.5 34* offset fit on an X MR with stock suspension running 265/35/18 Z1 Star Specs without using spacers?
I haven't seen any 34* CE28Ns yet...
Thanks!
Old Apr 5, 2011 | 06:35 PM
  #70
duhveed's Avatar
Thanks!
You'll need spacers
I have +22mm offset and you can maybe fit a credit card between the caliper and wheel haha
Old Apr 5, 2011 | 07:05 PM
  #71
Evo Tengoku's Avatar
Thanks!
https://www.evolutionm.net/forums/ev...-x-ta-ces.html
Old Apr 5, 2011 | 07:36 PM
  #72
Originally Posted by duhveed
You'll need spacers
Thanks for the tip. Ack! I really don't want to run spacers as I'm planning to track the car and don't want to worry about spacer issues...
Thanks for the link. It's actually this guy's old set that I'm thinking of buying. He doesn't say that he ran spacers initially but later he put on 10mm for a more flush look. I'm wondering if they fit initially w/o spacers and he just added the 10mm later for aesthetics only?
Old Apr 5, 2011 | 08:02 PM
  #73
EVOnicXVII's Avatar
Old Apr 6, 2011 | 12:55 PM
  #74
The difference is that 18x9.5 +34 ce28n spokes are more flat and not as concave. Flat face = more caliper cleareance.
Pretend you're looking at a cross section of a rim. A flat face rim would look like a " T " where a concave face looks more like a " Y ". You can see how the wheel profile will effect brake caliper cleareance.
19x9.5 +22 ce28n spokes arent as concave as the 18x9.5 +22 which is why you guys running the 19's will have more cleareance than the picture posted above.
Old Apr 7, 2011 | 09:43 AM
  #75
Chebosto's Avatar
18x9.5 +22 CE28N OE brembo clearance
18x9.5 +22 CE28N w/ 5mm spacer w/ Stoptech Trophy 6 piston clearance (Trophy comes out 3mm further than OE brembos)
18x10.5 +18 CE28N w/ Stoptech Trophy 6 piston clearance (Trophy comes out 3mm further than OE brembos)
18x10.5 + 18 RE30 w/ Stoptech Trophy 6 piston clearance (Trophy comes out 3mm further than OE brembos)
wheel line up
