Phantom X Evo PB progression thread
Old Jan 19, 2011 | 02:12 PM
Phantom X Evo's Avatar
New pics with Spec-Rs added.
Old Jan 19, 2011 | 05:06 PM
lpy2009's Avatar
looks so much nicer now , could you measure your ground clearance with the spec-R ?
from ground to lowest point of front bumper , thanks !
Old Jan 19, 2011 | 05:55 PM
Let me wait until they fully settle, but yea I will.
Old Jan 19, 2011 | 08:50 PM
lilgunz's Avatar
Looks good man, how do those springs ride? lose much from stock, I am stuck between these or the Eibach pro kit, as that is what I had on my VIII. looks good man, think I made the decision I am gonna go with the black RPF1, same size and all.
Old Jan 19, 2011 | 11:05 PM
Malik_EvoIX's Avatar
rpf1's look good on the car
Old Jan 20, 2011 | 12:35 AM
bfresh's Avatar
Those AEM gauges look ill bro I really like how they go with your setup.
Old Jan 20, 2011 | 02:51 PM
Thanks, the springs feel just slightly stiffer than stock. If you are looking at these or eibachs, I would recomend these all the way. The spring rate is much better than the eibachs, almost the same as the GT WORX springs. The height is .25 inch higher in front than eibachs and the same height in the back.
I picked the AEMs just to match the factory cluster, thanks.
Old Jan 20, 2011 | 03:15 PM
wrxnevox's Avatar
looking good!
Old Jan 20, 2011 | 03:30 PM
Deraj's Avatar
Nice ride. You've inspired me to get spec-r's
Old Jan 20, 2011 | 06:09 PM
mr2dsm's Avatar
Looks good! But i did hope that the front would sit just a bit lower...
Old Jan 21, 2011 | 06:45 AM
Evo Tengoku's Avatar
Looks good on the Swift Spec R. Did you rub in rear?
Old Jan 21, 2011 | 08:29 AM
I have not noticed any rear rubbing. I think the front might be rubbing slightly at full lock.
Old Jan 21, 2011 | 08:57 AM
Hope this works.
This is the front undertray ( actually lower than my front bumper) and has about 3.75", the lowest part on the actual bumper is about 4.25".
This one is the lowest point on my car ( besides the tires ) the artisan exhaust is pretty low. It is about 3" from the ground.
Old Jan 22, 2011 | 12:48 PM
Yoo Shin's Avatar
Nice! I'm curious about the springs also, as there hasn't been as many people going or switching to them than I thought.
Have they settled any and can you give any hub to fender measurements? I'd like to compare it to my buddy's Swifts to see to get a better perception of what the delta is.
Old Jan 22, 2011 | 05:02 PM
From the Swift website. Here is your delta.
Swift Sport springs /............spring rate............./............Drop............/
.................................F 4.3Kg/mm, R 4.4Kg/mm....F 1.0inch, R 0.6inch
Swift Spec-R springs /............spring rate............./............Drop............/
.................................F 5.3Kg/mm, R 5.3Kg/mm....F 1.3inch, R 1.0inch
