shift knob for SST evo's
Old May 1, 2012 | 12:38 AM
menasor's Avatar
So close to ordering the Anvil 2. Now I'm back to debating between the Anvil and the Anvil 2. Anyone have a pic of the Anvil on the SST?
Old May 1, 2012 | 02:48 PM
initial_d2k's Avatar
here u go
Old May 1, 2012 | 03:18 PM
menasor's Avatar
Originally Posted by initial_d2k
here u go
Thanks initial_d2k! Is that how it sits normally? Is there a way to make the ball sit lower? I'm comparing to wthoevo8's pic of the Anvil 2 and his seems to sit quite a bit lower. Thanks!
Old May 1, 2012 | 07:48 PM
for sure, it came with 2 nuts and a washer. I used all 3 of them, I assume I can make it significantly lower (2mm to 5mm) lower if i remove the washer or one of the nuts.
might try this tomorrow =)
Old May 1, 2012 | 09:09 PM
wthoevo8's Avatar
Looking at d2k's pic. There's still some lowering left for the pull up to be clear.
Old May 2, 2012 | 05:32 AM
RAzero's Avatar
just to confirm with d2k. Theres no ugly gaps or anything. The anvil sits flush and everything works fine? If so i'm getting one. Looks so good!
Old May 2, 2012 | 08:10 AM
menasor's Avatar
Sounds like it will definitely sit lower and be perfectly flush if he just uses one less washer or nut. I would just order one if I were you These knobs are countersunk so there's plenty of clearance for the reverse lockout
Old May 3, 2012 | 01:00 AM
menasor's Avatar
Just ordered the Anvil 2 in stainless. Will post pics when I install it!
Old May 3, 2012 | 07:39 PM
Just went down and snap some pictures for you guys:
This the "nut-washer-nut" configuration before
And this is how it look when i leave one nut only:
It surely looks a lot better. I will use it for a while and see if there's any issue with the pull-up with day-to-day driving.
At worst, I will add one nut back without the washer.
Old May 3, 2012 | 07:46 PM
Evod350z's Avatar
Wow that looks really good. Perfect height. Im ordering one.
Old May 3, 2012 | 08:00 PM
BTW, thats the Moddiction Titanium Shift Knob - 2" Round Anvil - Brushed Burnt finish
I just checked their site, it seems to be running out fairly quickly.
a small note:
The actual color looks less purple than the picture on their product page.
You can compare the picture i first posted vs the one on their site.
Old May 3, 2012 | 11:03 PM
menasor's Avatar
Wow looks really good! Maybe one nut plus the washer if you're having issues? How does it feel so far?
Old May 4, 2012 | 05:45 AM
No issue so far; I think 1 nut is alright =)..
Old May 4, 2012 | 08:51 AM
New day time shot with the new low config
Old May 4, 2012 | 09:25 AM
jdmrBeast's Avatar
Loving the ti-shift knobs! More please..
