Touch up paint pen advice
Old Jun 21, 2013 | 06:24 AM
ethics's Avatar
Hello all, I have oem touchup paint pen and am going to touch up a few small scratches/chips...I am just looking for advice/tips....I am going to wash car and dry before but was wondering is less more in regards to paint pen? should I do multiple touchups or one? Thanks in advance...
Old Jun 21, 2013 | 06:45 AM
ryancb's Avatar
multiple till its a globb then buff/polish it flat and clear coat it. need a couple day dry time between each coat and at least a week on final IMO
Old Jun 21, 2013 | 07:25 PM
skellin's Avatar
I would do multiple thin layers. You want to build it up.
Old Jul 1, 2013 | 03:03 PM
ikt@evoxpod.com's Avatar
scratches will probably buff out or wetsand/buff
touch up pens apply a lot of paint all at once. You're better off with a real color matched lacquer and touch-up dabbers. I have a bunch of D06 Octane Blue paint, I can pour your some to use if you want, no charge. Dab it lightly little bits at a time, wait about 15 minutes between coats. Finish with clear coat but using a clear coat pen. Dab the pen onto paper, then use a real touch up dabber to put the clear on.
To prep it, you don't need to wash/dry the whole car, just the area where you're touching up.. If you can get some grease/wax remover, use that. If not, rubbing alcohol. Those little pits get full of wax over the years and it makes paint not hold well.
Burnstormer
Mar 3, 2016 03:07 PM
milenko11
Jul 26, 2010 01:32 AM
EzEddie
Feb 6, 2006 10:45 AM
