#22/350 Canadian Final Edition EvoX
thank you!
i actually made that mount. I cut a piece of metal into a rectangle about 8” long and 2.5” across and made it into a ‘Z’ shape, with 2 holes on each end! Then purchased a universal plate mount attached it via Nut & bolt on one end.
Now to mount it to the body, if you look at the top corners of the mesh of the FMIC area you’ll see two 10mm bolts hidden. I just unbolted one, snuck the other end of the ‘Z’ mount in and replaced the bolt!
If you have any other questions just shoot me a DM on instagram! @xerxesbillimoria
