TPMS problem with Work 11R-FT
I recently bought Work 11R-FT and had new tires mounted onto them. The shop swapped over my stock TPMS sensors and within an hour the tires were down on air, and one was even flat. I had them redo the valve stems with another rebuild kit and this helped, but the tires were still losing about 1 lb or more of air per hour.
The shop claims that the stock TPMS sensors do not sit correctly inside of these wheels and I have since had to switch to the valve stems that came with the wheels so that I don't need to be around an air compressor every couple hours.
I searched and saw that a lot of people were able to swap their stock TPMS sensors to their new aftermarket wheels without any issues, but I can't seem to get mine to work. Any suggestions??
That sounds really strange. If I were you, I'd ask the tire shop to dismount a tire in good faith to show you why it's not working. My guess is the angle of the tpms base makes the valve stem not sit flush in the valve stem opening causing a leak. You could possibly get a new set of tpms sensors? But I'd ask to see it first.
I had the same issues with the exact same wheels. The first time I got them back from the shop, they all leaked and were pretty much flat within an hour. I had the shop redo them and for awhile, they all held air fine. Now, one of them is starting to leak about 6lbs a day....maybe I ran over something and have a real leak in the tire. I'm actually going to my friends place today who happens to have a lift...gonna get the soapy water out and check for tire leaks.
Only thing they said was they just had to work with em a little bit to make them hold air. I'll get details on what they had to do and report back soon.
I doubt work or any of their dealers would be able to remedy the situation.
The only thing I can think of is a possible aftermarket tpms sensor fitting. Or just doubling up lots of 3m double sided tape and using that to bridge the gap between the tpms and the wheel.
So I talked to the tire guy today. He said sensors weren't seated very well, my car was worked on by the new guy. The ferule nut was also not tight enough. It has to be properly torqued with tires off the rims. I'm not a tire guy so I'm just gonna take their word for it.
I did check my valve stem today and it's fine, I must have just ran over something and put a tiny puncture somewhere on the tire. It sat in the shop at 36 lbs all day, there's probably a hole that gets a little bigger once the tires heat up? Dunno.
Anyways, I hope you get it figured out man. They're a really nice set of wheels. Damn if we could just find some way to delete the sensor.
I ended up having the morons just put the valve stems that came with the wheels in for now and will take it to a more reputable shop, unfortunately at a much higher cost.
Also, I looked in the bag that the shop put the TPMS valve stems into and noticed that they snapped one of the sensors in half...fantastic. I now have to pay out of my pocket to replace this sensor. I called into their corporate office and filed a complaint stating that the people knowingly broke one of my sensors and failed to inform me or do anything to rectify the situation.
This entire experience has been less than ideal and has led me to second guess any possible chance of changing my wheels in the future.
Update: I put a crap load of air in the leaky tire, then got em' nice and hot. Parked and sprayed my soapy water on the valve stem. It's leaking from the base of the ferule. I'm betting the seal failed or something.
So yeah, I'm in the same boat now. Works coming off and being donated to a friend who doesn't care about the light. His stocks are going on my car so I don't have to worry about yanking out sensors that are possibly damaged. No more drama. Now I just have to figure out if the dealer can pick up the serial numbers from the sensors while mounted (like toyotas) or will they have to be read for the sensors themselves.
I have the same problem with my 5zigen FN01RC.
The problem is the opening for valve stem on the wheels is a lot bigger than the diameter of the stem of our TPMS, that's why it wasn't sealing at all..
I believe you'll need one of those:
http://www.iforged.com/store/product...products_id=10
or
http://www.iforged.com/store/product...products_id=11
I have never tried any of these product, but I'm planning to get it done once and for all next time i change tires.
or
or
or
