Sway bar bushings
Sway bar bushings
I just replaced my sway bar bushings, and seemed to be a pretty straight forward deal. Tonight I noticed that if I turn left right lock to lock, it actually slightly moves forward and backward. A slight amount like when the e brake is released, so a few inches. Do sway bars need to be centered or aligned a certain way when the bushings are changed? I can't think of anything else that would be causing this.
No, not really. It seems like you tightened up the sway bar when it was under load - like the wheel wasn't quite straight. I presume this is for the front right? You might try making sure both wheels are off the ground, straight and then loosen the sway bar bolts, then tighten them up again.
With the old bushings I was able to move the sway bar by grabbing and pulling when there was no load on it. Can't do it with the new bushings. Is there supposed to be some left right play?
MisUnderStood
20
Jan 18, 2016 05:57 PM
deylag
Jul 27, 2011 06:29 PM
love67
Apr 26, 2011 02:49 PM
LiftedLegion
Nov 12, 2002 10:20 PM
