Tpms Off
I was watching the MITSU training vids and there is a lot that the dealerships can do I bet they can turn it off if you want. I know that they can resync them if you ever change a wheel I bet someone knows something. JUST A GUESS
I was told, they had a customer ran some wheels without the tpms sensor for few days. and it threw up massive amount of CEL and codes. Far as he is aware. there is not way to turn it off.
i hope its not like other ones where you have to reprogram every time you rotate the tires to makes sure the computer knows where each one is. sometimes its a pain in the butt.
There are 2 ways around this.
The simplest method is the zip tie method. The sensors work on pressure applied to the unit while it is inside the wheel. Simply remove the units from the wheel, put a plastic spacer in between and zip tie them together. You will need to do this quite tight to fool them into thinking there is enough pressure being applied. Simply throw them in the glove box, trunk, etc.
The other method takes longer to fabricate, but is easier to regulate the proper pressure. Basically, you make a pipe bomb for the sensors.
You will need:
12" X 3" PVC pipe
2 X 3" PVC end caps
PVC pipe glue
3M double side tape (foam type)
I believe it is a 3/8 in drill bit and rill
Glue one end cap to the pipe.
Using foam tape, attach 3 sensors inside the tube (taped so they will not rattle around).
Drill hole in other end cap.
Insert last sensor inthe the hole in the end cap. Reattach hardware so it is sealed.
Glue end cap onto pipe.
Let dry over night.
Inflate to proper amount and hide in trunk.
You will need:
12" X 3" PVC pipe
2 X 3" PVC end caps
PVC pipe glue
Let dry over night.
