Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Why 9 & 9.5?
Old May 21, 2008 | 02:42 AM
slonez's Avatar
Why 9 & 9.5?
Sorry for a noob question.
I observed that quite a number of members running 18 x 9 or 18 x 9.5 on stock tires, is there any distinct advantage in running wider rims?
I would think that narrower/lighter rims would improve pickup....
Old May 21, 2008 | 03:17 AM
svtkiller's Avatar
OH Brother!!!!!
Old May 21, 2008 | 03:34 AM
alloutDSM's Avatar
haha no, the wider the tire you have the better foot print you have so there's more traction lol where did you hear that?
Old May 21, 2008 | 04:56 AM
slonez's Avatar
I am referring to the rim size, assuming the tire size are the same.
Old May 21, 2008 | 11:46 AM
JoeyM3's Avatar
they are to run wider tires, i think a lot of the ppl will run the stock tires just so they dont have to buy new tires, im sure theyll run bigger tires when they replace them
Old May 21, 2008 | 11:51 AM
Protostar1's Avatar
A wider rim using the same tire will stretch the tire more allowing for a slightly larger footprint but also decreasing the sidewall height making them less suitable for daily driving. depending on how wide the rim is and how narrow the tire is, you could also have sealing issues between the rim and the tire. Go to tirerack.com to view the stats chart for your specific tire to see what range of rims will work with it. Generally a wider rim is simply to put a wider replacement tire on it.
Old May 21, 2008 | 04:29 PM
slonez's Avatar
Thanks guys!
SinCityEvo9
For Sale - Wheels / Tires
10
Mar 23, 2012 05:32 PM
Joshs EVO
16
Apr 6, 2009 08:47 PM
Ultimate CC
17
Jan 20, 2007 01:58 PM
CarFanatic
May 22, 2006 06:46 AM
evo8silver
12
Aug 1, 2005 07:00 AM
