Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Evo X wheels fitting problem / Advan RZ 19"
Old Aug 4, 2008 | 02:41 AM
Sapik's Avatar
Hello
I have a question. I own an Evo X, lowered with Eibach springs and I am about to employ Advan RZ 19x10 wheels offset 25mm, they are in fact already ordered. I am worried if these will fit. I'm afraid they're going to be too wide, looks like the spring mount in the front will be in the way. Any answer greatly apreciated, I am quite worried I'll have to buy an adjustable suspension as well.
Thanks for your help!
Old Aug 4, 2008 | 04:56 AM
Hiboost's Avatar
It would also depend on what size of tires you are mounting on the rims. Even the same size can be slightly different from one brand to another. Maybe someone with similar stats on their wheels/tires can chime in for clearance comparisons.
Old Aug 4, 2008 | 05:06 AM
Sapik's Avatar
I'll use 265/30 max.
Old Aug 4, 2008 | 05:12 AM
Robevo RS's Avatar
you need more camber
Old Aug 4, 2008 | 08:26 AM
StevenStarke's Avatar
I have 19x10 enkei rpf1's with a +22 offset. I have 285/30/19 sized tires and my car is lowered on RobiSpec KW coils. I had rubbing in the back on bumps so i rolled the fendors and now it only rubs on Hard bumps if I have someone in the back seat (very rarely) BUT the front also rubs on full lock turns, like when i'm pulling out of a driveway or something. 275/30's would have been better but 285 was closer to stock rolling diameter
Old Aug 5, 2008 | 02:40 AM
Sapik's Avatar
OK I am sure the the tyre has to be lower profile, but I am worried it won't fit because of the shock mount - that it's going to lean against the shocks. I own a GSR Evo X, EU spec but I think it's mostly the same as US spec, as far as I know only the shocks are of a different brand. Please tell me what you think,
thanks for your reply
Old Aug 5, 2008 | 08:26 AM
DarksideEng's Avatar
No, they will fit fine. They will not hit the strut. People (including our shop car) run wheels that are closer that your Advans to the strut and are fine.
Old Aug 5, 2008 | 08:39 AM
DRFTKNGG's Avatar
They fit only you will have to have the rear fenders rolled
Old Aug 5, 2008 | 08:46 AM
dude, i have .5" wider rims then you and run larger tires then you plan on running and its not hitting my shock mounts
Old Aug 5, 2008 | 08:54 AM
Your wheels are only 3mm closer to the strut than his Advans will be. That alone verifies the Advans fitment.
Old Aug 5, 2008 | 09:02 AM
I know, thats what i'm trying to tell him
Old Aug 5, 2008 | 09:36 AM
Sapik's Avatar
OK, thanks to everybody, I feel better. Thanks a lot for all advices. I am looking forward for receiving my wheels.
Old Aug 5, 2008 | 10:11 AM
DirectorSe7en's Avatar
I'm running exactly what you want to run. 19x10 +25 Advan RZ with 265/30/19 tires.
I've been lowered all the way to a no finger gap, and had no rubbing issues, no body modifications and no camber adjustment.
You will be fine.
Old Aug 5, 2008 | 11:06 AM
Hiboost's Avatar
BTW I was able to get -2.0* camber front and -1.0* camber rear with just Eibach lowering springs, seems like it's enough so far. Eventually I'll be looking at wider wheels and tires for this car, just won't be until next spring at the earliest. Glad you guys are testing all these combos out!
Old Aug 5, 2008 | 01:07 PM
raz's Avatar
raz
Smile
hi i have work xc8 19x10 with 35 offset they fit fine with 265/30 19 no rubbing of any kind front or rear, they are for sale if any one is interested
