Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Spring Rate Chart for Evo X
Old Dec 1, 2010 | 04:33 AM
  #46
Phantom X Evo's Avatar
Swift Spec-R......5.3kg......5.3kg.......1.3/1.0..........350
Old May 22, 2011 | 05:09 PM
  #47
Iowa999's Avatar
Someone posted pictures of Tein S-Techs for an Evo X and they were clearly progressives, so the chart is a tad misleading on these. And before you ask, no, I have no idea what the actual rates are.
Old Jun 28, 2011 | 07:27 AM
  #48
Hiboost's Avatar
Ok guys I've been slacking over the last year but have learned quite a bit more in my travels when it comes to suspensions. I intend to update the charts and will give some basic suspension tips that will give you a good starting point for setting up a car that can handle turns as well as go in a straight line.
Old Jul 7, 2011 | 10:16 PM
  #49
Bigstakk's Avatar
Just an FYI, I have the Eibachs and they are lower than advertised I would say ~1.5"F/1.0"R
Old Aug 1, 2011 | 06:47 AM
  #50
Hiboost's Avatar
Indeed, when I had those springs they easily dropped the front 1.5" and it was right at the limit of how low you would want to go on the stock shocks.
Old Aug 8, 2011 | 11:25 AM
  #51
GTWORX.com's Avatar
The spring rates posted for our springs is incorrect. They are 300 lbs/in front and rear, which is about 5.55 kg/mm
- andrew
Old Aug 18, 2011 | 06:32 AM
  #52
Hiboost's Avatar
- andrew
Wow those are quite a bit stiffer, not sure where I saw the specs before, updated the chart!
Old Oct 8, 2011 | 12:30 PM
  #53
Bigstakk's Avatar
Side note- is the spring rate chart accurate...i noticed a few of them didn't seem right like the gtworx which my understanding they only drop it .8in F/R and the spring rates are not that stiff either...
Also, does anyone want to sell me their Works springs?
Old Dec 19, 2011 | 09:34 AM
  #54
ak47m203's Avatar
to OP can you update your list with Progress spring. Top 2 spring for me GTWORX Tarmac and Progress.
GTWORX Tarmac ............ 5.5 kg ................ 5.5 kg ............. 1.2" / 1.0" ................. $299
Progress ........................ 4.6 kg ............... 4.1 kg .............. 1.2" / 0.8" ................. $190
GTWORX has a higher spring rate but can you fell it obviuosly compare to Progress? Progress is nice for that price.
Old Mar 7, 2012 | 10:20 AM
  #55
Hiboost's Avatar
Originally Posted by Kryx
OP do you want to add the swift spec r's? Lowers 1.25" F and 1" R, and 5.3kg F and 5.5kg R
Just added and I also updated info on the Robispec and other KW coilovers out there.
Old Mar 7, 2012 | 10:32 AM
  #56
Noize's Avatar
EvoM Administrator
Thank you for doing this, Chris!
Old Apr 5, 2012 | 09:29 AM
  #57
evofan_08's Avatar
Sup guys, Any info on which springs come with the Tein Monoflex coilovers? Mine are making my teeth hurt since I hit 30 years old lol and I'm going to change the springs in hopes of taking the harshness down a notch.
Also, I found out that if your coil over set up has a camber plate then you have to lubricate the spherical bearing in the center of it or it will wear out eventually causing a horrible knocking/creaking metal on metal sound.
Found this info on Maintenance and cleaning
http://teinusa-blog.com/tein-damper-maintainence/
http://teinusa-blog.com/so-fresh-and-so-clean-clean/
Old Nov 22, 2012 | 10:11 PM
  #58
Bigstakk's Avatar
Talked to Muellerized the other day and they told me their springs have a spring rate of 4.3kg (f)/4.4kg(r) in case the OP wants to update that on the chart
Old Nov 28, 2012 | 07:39 AM
  #59
eug!'s Avatar
Not sure if anyone posted Hotchkis spring info but here it is:
DROP: Front: 1.5" / Rear: 1.0"
SPRING RATES: Front: 195 lb/in. / Rear: 275 lb/in.
Old Jun 19, 2013 | 01:15 AM
  #60
EndlessRed's Avatar
Info for Cusco Zero-1:
Spring Rates: F: 9kg/mm, 504lb/in R: 8kg/mm, 448b/in
