Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
tire size
Old Aug 19, 2008 | 07:16 PM
feli3344's Avatar
tire size
whats the largest width and recommended profile you can use on stock gsr wheels with eibach springs?
Old Aug 19, 2008 | 07:37 PM
Robevo RS's Avatar
You can go one step over the factory without any problem for sure ./ 255/
I think the 265 will have no noticeable advantage over the 255's on the factory rims.
Old Aug 19, 2008 | 11:02 PM
bli8's Avatar
I was looking to see if I could put 265 tires on the OEM rims but found out the max. size for 8 1/2 inch rims was only 255.
Old Aug 19, 2008 | 11:08 PM
bli8's Avatar
Old Aug 20, 2008 | 05:56 AM
Pro-Spec's Avatar
It depends on the Brand of the tire.
Some 255 is wider than 265, so watchout....
