Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
rims for winter
Old Sep 25, 2008 | 01:45 PM
plip630's Avatar
rims for winter
hi!
just wanted to know if this rims will on evo x mr?
RTX Titan
18x8, 5x114.3, +40
Black w/machined lip
our stock rims is:
18 x 8.5, 5 x 114.3, +38
im just worried about the offset. also the tires im gonna put is 245-40-18 will it fit on the rims?
thanks
Old Sep 25, 2008 | 02:11 PM
goofygrin's Avatar
The wheels will fit (4mm more inner clearance, 8mm more outer clearance)... you might look at some Rotas in the stock size/similar offset. Cheap, like $700 through wheeldude.
Those tires would be a bit fat on those wheels.
Offset calculator: http://www.1010tires.com/WheelOffsetCalculator.asp
Don't forget hubcentric rings or else wobble and vibration is in your future!
