Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
springs install?
Old Oct 5, 2008 | 05:53 PM
Slimdatwelve209's Avatar
springs install?
i can't find a DIY springs install, but i just pick up Works springs and like to know if installing is the same for the X like for the VIII/IX?
Trying to save money and get it done myself
Old Oct 5, 2008 | 06:09 PM
J5isalive2's Avatar
should be pretty strait forward. get some spring compressors and go to town.
Old Oct 5, 2008 | 06:13 PM
kanyonkid's Avatar
I did my wifes springs on her 08 lancer... piece of cake... no DIY or anything, very straight forward and it was my first time...
GL
Old Oct 5, 2008 | 08:48 PM
gabesir's Avatar
dude soo easy took me a little less than 2 hours, on floor jacks and did it in the driveway! LOL
took longer to remove the wheels................ LOL
Old Oct 5, 2008 | 08:56 PM
NateDaJew's Avatar
I have to buy a spring compressor? Besides that it looks easy. Where did you place the floor jacks? ........ besides the floor
Old Oct 7, 2008 | 01:25 PM
Jamie@WORKS's Avatar
The included instructions should lay out the procedure pretty well. If you didn't get a copy in the box, shoot me an email: jeasley@worksmotorsports.com Yes, a spring compressor (and an impact gun) will make the job easier. They can usually be rented/purchased from an auto parts store if you don't have a set. Jacking points are outlined in the owner's manual (basically at the notches along the pinch weld running down the side, the rear diff and the crossmember up front if you have the undertray off).
Old Oct 7, 2008 | 02:30 PM
NateDaJew's Avatar
You should post a DIY in the "how to" forum. Thats good advertising. Thanks for the info.
Old Oct 9, 2008 | 05:57 PM
wongck's Avatar
What happens if I don't use a spring compressor? Will the spring just launch into space when I remove the top hat on the struts?
Old Oct 9, 2008 | 06:41 PM
SpeedI2acerX's Avatar
that are you lose your head
Old Oct 9, 2008 | 07:13 PM
PlayinWithFire's Avatar
that and you wont be able to get the new ones on the strut. Think about the amount of weight they hold up, i doubt anyone can compress them enough with bare hands.
edit - they r only like 50 bucks from eastwood...
http://www.eastwoodco.com/jump.jsp?i...emType=PRODUCT
Old Oct 9, 2008 | 08:03 PM
element2zz's Avatar
no spring compressor = death + it just cant be done....
Old Oct 9, 2008 | 08:05 PM
WWEVO206's Avatar
Get a spring compressor. I help do my uncle's evo x. It was easy
Old Oct 9, 2008 | 08:12 PM
actually if you had wicked strong teeth..
edit... or this http://www.youtube.com/watch?v=0Mt1UBTp0zk
Old Oct 9, 2008 | 10:53 PM
J5isalive2's Avatar
how about this.... LOL
http://www.youtube.com/watch?v=XEQq0...eature=related
Old Oct 11, 2008 | 05:59 PM
ashyking's Avatar
it's probably the same
just be safe and use the right tools.
spring compressors and air tools do wonders.
