Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Correct Tire pressure?
Old Dec 9, 2008 | 03:27 PM
slonez's Avatar
I am a little confuse!
Different tire shops tell me different thing about the correct tire pressure for tracking.
1. 30psi all round so that contact surface is maximized. Monitor pressure during tracking session, release pressure as tire get heated during track session.
2. 38psi front, 34psi rear. No need to release air during track session. Higher pressure in the tire means the pressure is more stable when tire is heated up.
Can experts here provide some advise? Thank you.
Old Dec 9, 2008 | 04:40 PM
markpaco's Avatar
The starting tire pressure is about right such that you end up in the mid to high 30s. This is safe and correct. As far as the correct tire pressure to run, a normal operating pressure (NOP) of the manufacturer's spec is a starting point. I, personally, would run at NOP slightly higher than stock.
Yikes! By the time you get to normal operating temperature/pressure, your tires will be around 45-50 psi! While it is true that the tire will be more stable when heated up, starting at a cold pressure of 38/34 f/r will result in a high NOP. This is VERY DANGEROUS. The turn-in response will be very good but the ultimate grip will be low and the car will be very skiddish and unforgiving.
Old Dec 9, 2008 | 07:27 PM
slonez's Avatar
Is there an optimum pressure when heated? Should I monitor this instead?
Thks.
