Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
What alignment to run with Eibach springs?
Old Mar 15, 2009 | 05:06 AM
Cornerstrike's Avatar
For those who have Eibach Springs installed already, I was wondering as to what would be the best alignment setting to run on the X? Mine will be a DD car, but Im sure some you of track the car once in a while. I would think that whether you have the stock wheels and tires or aftermarket wheels would make a difference. Then again, the reason why Im asking is because Im not sure. I most likely will be installing the springs around May, along with some 18x9.5 +28 set of wheels.
So, what do you guys recommend?
Old Mar 18, 2009 | 11:32 AM
Will anyone share some info about this?
Old Mar 18, 2009 | 11:50 AM
goofygrin's Avatar
search?
More: wheels don't make a huge difference. Run either stock, stock like or agressive alignment (specs are in the search results). This has been covered a multitude of times.
Old Mar 18, 2009 | 12:17 PM
macPSU's Avatar
I'm running the stock alignment on my Eibach springs.
+1 on searching, there are a few results out there.
Old Mar 18, 2009 | 07:10 PM
I did a search and found some info, but nothing definitive. Here's an example:
https://www.evolutionm.net/forums/ev...alignment.html
Im just trying the right specs for the drop. Dont want to experience the same issue as the guy in the thread above.
