Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Cobb sway bars question
Old Mar 24, 2009 | 08:11 AM
GTWORX.com's Avatar
Originally Posted by R0ME0
Andrew,
What are your thoughts on a front sway bar? I heard on the X its not needed. That front is overkill and the rear is all that is needed?
With the weight of the X, I do think both the front and the rear are a good way to go. Swaybars are a good cheap way to increase roll resistance and they don't impact ride quality much. The X definitely needs a lot more roll resistance for serious driving.
So I say get both if you can. If you do get just 1, go for the rear....partially because the install is so much easier. But you would see a much greater benefit from getting both.
- andrew
Old Mar 24, 2009 | 08:20 PM
Cyp's Avatar
Cyp
Originally Posted by abu
Here's a link to some instructions. You should get an alignment afterwards from the looks of it
DOE!! those instructions tell you to take your whole car apart before installing the front sways...OUCH!! Wonder what the cost for labor would be to install those?
Old Mar 24, 2009 | 08:34 PM
Cyp's Avatar
Cyp
Originally Posted by sohcpunk
Just reporting back from my install this Saturday. I got both bars installed at HB Speed. They took awhile to finish up but I gotta say this is one of the best bang for your buck mods. They car turns really flat and body roll is pretty much eliminated. Steering feel also feels tighter and more in control. I spoke to the technician that did the install and he said I would not need an alignment. I will be keeping an eye out for tire wear to make sure its okay.
What settings did they setup your front and rear?
Old Mar 24, 2009 | 11:36 PM
sohcpunk's Avatar
Stiffest for both front and rear.
Old Mar 25, 2009 | 08:23 PM
navidf's Avatar
Once on one setting for the sway bars, what do you need to do to change to another setting? Is it difficult/time consuming to do?
Old Mar 27, 2009 | 05:07 PM
sohcpunk's Avatar
I believe it's a matter of getting your car on 4 jack stands and unlinking the endlinks and relinking it to the new setting.
Old Mar 27, 2009 | 05:39 PM
Clark_Kent's Avatar
^Correct. The process should take less than 10 mins.
Old Mar 28, 2009 | 07:48 PM
raytrix's Avatar
Assuming the bolts at the end-link aren't rusted and that you have an allen key that isn't snapped in half because of the force you need to apply to those damn rusted nuts to loosen it
Old Mar 28, 2009 | 07:52 PM
Clark_Kent's Avatar
Haha, rusted bolts already?
Old Mar 29, 2009 | 07:47 PM
sohcpunk's Avatar
Looks like Chicago uses salt to clear its roads.
Old Mar 29, 2009 | 09:13 PM
aftershock141's Avatar
And sand.
Old Mar 31, 2009 | 10:50 AM
NoJoy II's Avatar
Has anyone added a rear brace to their X and the rear sway bar? Is that overkill? I am thinking about the Cobb rear sway bar as well, but the rear OEM brace would be nice to have too.
Old Mar 31, 2009 | 07:45 PM
smgevo's Avatar
Are you talking about the rear strut tower brace? If so, it functions independent from the sway bar and therefore not overkill at all.
Old Mar 31, 2009 | 10:22 PM
NoJoy II's Avatar
Yes the rear strut tower brace. If that would help the stiffness of the rear of the car I think I am going to put one on including the adjustable sway bar.
