Suspension Help??
Yesterday I took one wheel off cleaned it and put it back on. Today I go for a drive and the steering is loose. The car also pulls to the right and there is a loud thuding noise as if I had a flat tire
The counter weight is still on the outside of the rim but does anyone know if the inside has one as well? All the lugs are tight and I don't see any broken suspension parts at a quick glance.
Anyone have any ideas because I can't drive it at this point. Just checking here first because the dealer is over 1 hour away.
Thanks
Thanks
Have you ever taken the wheel off before? Sound like you didn't attach the wheel back on correctly... Did you center it on the hub and check the torque on the lug nuts?
I did notice that the gap from the tire to the fender was wider than before the wheel came off. It's almost like something happen to the shock or spring was unseated. I also lost brake pressure twice within a couple miles and I had to pump the brakes to get it back. It's on the way to the dealer now anyway so I just see what they say.
