Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
spring seating question
Old Apr 7, 2009 | 11:26 AM
Silversx's Avatar
had my eibachs installed yesterday
i noticed that the right rear spring bottom seat has a 1 finger space between the end of the spring and the end of the seat.. that perch that stops the spring
is this a problem? i don't hear any noise and the drop is perfect.. got it aligned already so i don't want to take it apart just to rotate the spring by half an inch
i hope this makes sense..
Old Apr 7, 2009 | 11:32 AM
evolutionXmute's Avatar
is there a gap the entire way around at the bottom of the spring?
Old Apr 7, 2009 | 11:51 AM
Silversx's Avatar
no just a 1/2 inch gap between the end of spring and the metal indent that stops the spring on the seat
Old Apr 7, 2009 | 04:26 PM
Silversx's Avatar
anyone ??
by the way im not talking about a vertical gap.. but a hortizontal gap between the end tip of the coil and the metal perch that stops the spring from rotating down further
Old Apr 7, 2009 | 04:59 PM
Silversx's Avatar
here's a pic i jacked off the net and then marked up in paint to better illustrate my question
this is the gap im talking about
Old Apr 8, 2009 | 07:33 AM
Hiboost's Avatar
I'm not an expert by any means but if it's just a 1/2" space there it shouldn't be a problem to leave it alone. Worst case it will seat itself if it wants to over time which might slightly effect aligment but likely not too much. I think it's why people wait a week or so to get the car aligned after getting springs so that everything can settle and seat itself. I would imagine that you could weld in a spacer of sorts to raise the ride height slightly for a set of springs that were too low as well, assuming they would still seat in the perch.
Old Apr 8, 2009 | 08:21 AM
GSXR's Avatar
I had that problem when I installed springs on my wifes SUV. It was fine for a week or two and then it made some clunking noises when you turned the steering wheel in low speed driving (like a parking lot). I reseated the springs and the noise went away.
I'd say leave it alone and if you hear some noises, you'll know what it is.
