Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
Will A +35 Offset Fit A X?
Old Jul 17, 2009 | 05:31 PM
monkey_187's Avatar
I wanted to know if 18x9 +35 offset rims will fit my X, they are my old rims from my VIII. Will I need spacers or will they clear the calipers? I have 255/35/18 Star Specs on the rims.
Old Jul 17, 2009 | 06:05 PM
novaspyder87's Avatar
why not....I'm really not an expert,but we have +38 stock wheels.......+35 is really close so it could be good.....no???
Old Jul 17, 2009 | 06:23 PM
wilbdog's Avatar
Yeah - I just put +20 offset on my X...so sick!
Old Jul 17, 2009 | 06:43 PM
mangoes's Avatar
Should fit fine man, i have +12 offset on mine.
Old Jul 17, 2009 | 06:48 PM
zTargeTz's Avatar
PICS!
Old Jul 17, 2009 | 07:50 PM
macPSU's Avatar
The +35s should clear without a problem, but if you own a X why don't you just jack it up and throw a wheel on to see if it fits??
Old Jul 17, 2009 | 08:17 PM
JoeyM3's Avatar
i have +34 volks and they fit fine
Old Jul 18, 2009 | 03:19 AM
monkey_187's Avatar
I was suppost to pick my car up Friday but didnt have a chance to make it. Now I am out of town and cant get the car till Monday. I just thought I could ask, this way when I get it I can out them on right away.
Old Jul 18, 2009 | 05:59 AM
goofygrin's Avatar
the only issue might be the calipers. It's possible that they won't clear the brakes.
The tires are a poor size for the X though. Your speedo is going to be way off since those tires are shorter than the stock size by a good amount (use a tire size calculator).
Old Jul 18, 2009 | 06:15 AM
Robevo RS's Avatar
you will be fine . this X has a Ce28's with same size you have with a +35 off set , and 255-35-18
Old Jul 18, 2009 | 06:38 AM
macPSU's Avatar
Ahh, I see. Fair enough.
Old Jul 18, 2009 | 08:07 AM
eldiablo79's Avatar
What? Did you buy a X? What the hell?
Old Jul 18, 2009 | 09:29 AM
heavyD's Avatar
Yep. Some wheel designs may have an offset that is in the stock range but will still come in contact with the front calipers. If you are ever considering a wheel with an offset very close to the max it's always good to either look to see if someone else has tried the wheels or do a test fit before you put the rubber on.
Old Jul 19, 2009 | 05:41 PM
monkey_187's Avatar
Suspense is a MF! I will post pictures soon, the new project car is on its way.
Old Jul 19, 2009 | 06:51 PM
EvoG8r's Avatar
Its possible that a 35 offset could still hit the calipers. Just try em and see what happens.
