Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
What would you do? (need help again)
Old Oct 3, 2009 | 08:52 AM
dragon831's Avatar
ok here's the situation.... i got my eibach springs installed earlier in the week, everything is good. I have the stock wheels on right now though i have some new 265/35/18 nt05's with grids in my garage. I went to get an alignment today and was told that i need to get a camber kit for each wheel. Is this true? and if so where can i purchase?
So my other question is should i wait until after i get the alignment straight to put on the new wheels or would i be fine riding on the new wheels for a week until i can get the alignment. From the layout that the tech gave me:
Camber
front left : -1.9 (specified range -.6 - +.4)
front right: -1.2 (specified range -.6 - +.4)
front cross camber: -.7 (specified range -.5 - +.5)
rear left: -1.8 (specified range -1.4 - +.4)
rear right: -2.1 (specified range -1.4 - +.4)
rear cross camber: .2 (specified range -.5 - +.5)
Any help is appreciated thanks!! and where to get camber kits!
Old Oct 3, 2009 | 10:00 AM
stikllr13's Avatar
I dont know why you would need camber plates, even on the stock struts there is a good amount of camber adjustment that can be made. I am on springs and the same wheels you have, my alignment is at -1.7 in the rear and -1.3 in the front. And I could def go more negative if I needed/wanted to. Try going to a different alignment shop and see what they say. Hope this helps
Old Oct 3, 2009 | 10:28 AM
dragon831's Avatar
any more suggestions? they dont have many reliable shops around here, might have to take it down a notch. shouldn't i be shooting for around -1* camber on all 4? How much negative camber does it take to make a noticeable difference in tire wear?
Old Oct 3, 2009 | 10:39 AM
stikllr13's Avatar
Generally you want more negative camber in the rear than the front. And theoretically any amount of - or + camber will cause tire wear. But I would say that it becomes very noticeable wear with more than -2 degrees. I do my own alignments so it is just weird that this shop says that you need camber plates to do an alignment, thats just a lie lol.
rgonyer
19
Apr 19, 2011 05:55 PM
DJ Jazzy Death
Sep 7, 2010 08:15 AM
avo3vom
10
Jul 26, 2009 08:38 AM
idriveanevo
11
Jun 16, 2009 09:45 AM
Blacksheepdj
Lancer Troubleshooting
114
Dec 7, 2008 09:14 PM
