Quick Troubleshoot question
I am lowered with the Eibach Pro Kit. and I had it aligned a while back but recently my alignment is off again- Im actually taking it in today-the problem im seeing is that my front passenger wheel is angled in at the top- (negative camber but only one side) is this the alignment or something worse?
It's not super adjustable. See the sticky. When you reinstalled the struts I bet you forgot to make sure the top bolts were both installed the same (look for the white paint dot). Easy to do...
