This is from 2009.. Anyway, the NT03s need spacers ATLEAST on the front.
For caliper clearance or for shock clearance? cause I know the 18x10.5 30mm offset will clear the calipers and still have clearance from the stock shock. Not sure on aftermarket shock/coilovers
Bumping this because I feel it was way too hard to find the correct non-internet BS information around these wheels and fitment on a Evo 10.
I just installed 18x9.5 +27 NT03's on my Evo 10. The fronts need a spacer to clear the brake caliper. The rears need nothing.
I used 5mm spacers on the front. You *probably* would be able to get away with 3mm spacers but it would be pretty close. Here is the clearance with a 5mm:
Bump, any pics with the 18x9.5s? I like these wheels just don't want to go as wide as 10.5 or want some crazy offset and mess with the scrub radius or turn adversely.
18x9.5 +27
5mm front spacer. No spacer in rear. -3 front camber -1.8 rear.
