Evo X Tires / Wheels / Brakes / Suspension Discuss everything that helps make your car start and stop to the best of it's abilities.
alignment or balance problem?
Old Jun 13, 2010 | 06:07 PM
Fabrizio2000's Avatar
Weels shaking
Phuket, Thailand, My EVO 8 is ok To 190/200km/h , but dangerous at 220 because see the shaking on the steering and feel from the front weels , i replace the front stock Brembo with Alcon secondhand ,with new pads . is probably the rotor ?
Old Jun 13, 2010 | 06:19 PM
BoostWhore's Avatar
I would get your tires rebalanced first... could be a bent wheel, out of balance tire... are your wheel hubcentric to the rotors? alignments do not cause your wheel to shake.
Old Jun 13, 2010 | 10:09 PM
love67's Avatar
how to check if it is bent the wheel bearing??? i have problem with wheel shaking too. my oem wheel are all bent, so i replace them with new wheel and new tires, but the vibration is still here, but just less( it vibrates(just a little bit) at about 40mph and it will get more vibrate when the speed gets higher.). i re-checked the balance of my new wheels and it's 0:0...
so does anyone know what is wrong with my car? could be it be i bent the wheel bearing like someone mentioned? because i hited a big rock before, and i bent my wheel badly. or maybe something wrong with my roll center kit or lower control arm bushing?
thanks
Nick
Old Jun 14, 2010 | 02:07 AM
I 'm waiting my new rim and tyre ,so i will not spend money on check this temporary stock rims and burned on the side secondhand michelin tyres .......the reason is the garage damage my weels !!?? , so i have this temporary weels .
This problem only start at more than 115 mph , that why i was thinking about something more serious ..............Out of balance tyre or weel bent it should start shaking before ?
At 220 km/h ,i mean......... start to be an high speed . I was also thinking to the bushing .
turbotaloon95
Jan 23, 2015 06:48 PM
nodnarb
12
Feb 11, 2013 07:53 PM
AWDs
Apr 10, 2012 05:01 PM
bryan0
16
Jan 26, 2009 09:09 PM
Yorgis_MR
23
Jun 27, 2006 07:02 PM
